Old 12-04-2006, 01:25 AM
hexadec0079's Avatar
hexadec0079 hexadec0079 is offline
Parts Breaker, Tire Waster
Send a message via AIM to hexadec0079
Rough Idle and other Issues
I have a few questions:
Have had rough/ shaking idle for a while:
-Rocks engine a bit at idle, fine at all other RPM. [Fuel Filter, MAF, PCV,Plugs]
-Weird hesitation from 1800-2000 RPM [ECU bead crush?]
-Puffing sound from Pass. exhaust (true duals help, lol) [Leak?]
-Shaking at speed in AWD (better in FWD) [Alignment, tires, trans. break in?]
No check engine light, will pull code later today.
Thanks for your help
1992 SVX- -Drivetrain by BUDFREAK-
Green, LS with spoiler, 157,000, ES Swaybar bushings, 9005/6 mod, 2.25' Dual Exhaust, Custom Grounding, Hyperwhite fogs, LED tails, 4.44s, custom Blitz intake, tranny cooler, thats about it, for now...
1997 Chevy 1500 -FOR SALE-
5.7 liter, Z71, 300hp+, still almost 20mpg
1986 Merkur XR4Ti -SOLD-
SVO Engine, T3 hybrid turbo, K&N, custom ducting, Initial D painted, 18psi, fastest car for under $1000, ever.
Old 12-04-2006, 08:51 PM
No help at all?
Anything
Old 12-04-2006, 09:37 PM
Originally Posted by hexadec0079
No help at all?
Anything
You should appreciate that a specific reply requires specific information.
Old 12-04-2006, 10:13 PM
Ask away, I thought I provided enough info.
Old 12-05-2006, 05:16 PM
Hard to say with the info you provided. Rough running threads are here all over the place. Could be a vacuum leak or unmetered air allowed into the engine. If the CEL comes on check the code(s).
