Old 12-01-2006, 09:41 AM
hexadec0079's Avatar
hexadec0079 hexadec0079 is offline
Parts Breaker, Tire Waster
Send a message via AIM to hexadec0079
AWD Shakes???
Got my 4.44 done and it was fine for a day. Now, sometimes when I accelerate it just shakes. Most speeds, after warming up, after I did my parking lot figure 8s its worse. The whole car a bit. Pop the FWD fuse in, and its butter, even cut out some of my 1500-2000rpm hesitation. What gives. Is it the cluthces freeing after sitting for a while. Is it Sol. A related as I read in a thread that it had caused some binding. Any help would be very appreciated.
Thanks
1992 SVX- -Drivetrain by BUDFREAK-
Green, LS with spoiler, 157,000, ES Swaybar bushings, 9005/6 mod, 2.25' Dual Exhaust, Custom Grounding, Hyperwhite fogs, LED tails, 4.44s, custom Blitz intake, tranny cooler, thats about it, for now...
1997 Chevy 1500 -FOR SALE-
5.7 liter, Z71, 300hp+, still almost 20mpg
1986 Merkur XR4Ti -SOLD-
SVO Engine, T3 hybrid turbo, K&N, custom ducting, Initial D painted, 18psi, fastest car for under $1000, ever.
Old 12-01-2006, 11:36 AM
Anyone???
Got to get home soon. And is raining, need my AWD
Old 12-01-2006, 05:57 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Originally Posted by hexadec0079
Anyone???
Check your tranny fluid level just in case that little leak got worse or something.
I also sent you a PM. Anyone else have some ideas??
Old 12-01-2006, 06:59 PM
UPDATE:
ZOMG!!!!!!! The LSD additive is the BEST fix evAr. Added about 2-3oz. And went for a drive. No more than 1 mile later and after some round-abouts at 20 mph, its sooooo much better. 90% better, I'm sure the rest is from the crappy alignment. Hesitation is much decreased, I'm not sure about the Ecu bead as it is too low in the RPM, but I'll try to get to it tomorrow.
List for Sat.:
-Seafoam
-Change Oil
-Change ATF
-Alignment
-Pass. Sway bar bushing
Next Weekend:
-Brakes
-Secret suspension mods (shhhhhhhh!)
Old 12-01-2006, 07:02 PM
Budfreak's Avatar
Banned
UPDATE:
List for Sat.:
-Seafoam
-Change Oil
-Change ATF
-Alignment
Next Weekend:
-Brakes
Additive fixed it?! What the hell did they throw in it for fluid?? Remember, Change it after a couple hundred miles.
Old 12-01-2006, 07:04 PM
IDK, fluid looks BRIGHT red. I think it was were the Trans. sat for a month or so. But it is greatly improved.
Old 12-01-2006, 07:06 PM
Budfreak's Avatar
Banned
Let me get this straight. What kind of fluid did you put in and where did you put it?
Old 12-01-2006, 07:10 PM
Tube of LSD Additive from NAPA, about 2oz in Tranny
Old 12-01-2006, 07:17 PM
Budfreak's Avatar
Banned
IDK about that. I'd drain that out immediately,change the filter, and change to valvoline maxlife and run some tranny honey in it. I wouldn't want diff fluid in my tranny bro.
Old 12-01-2006, 07:37 PM
It is a Friction Modifier to slip the transfer clutches, where mine sat for a month in Japan and a week here and the transport, the sticking is reasonable.
Link to Source:
http://www.subaru-svx.net/forum/show...ight=lsd+fluid
I think I even read where you recommended it, maybe...
But it worked very well.
Old 12-01-2006, 07:42 PM
Budfreak's Avatar
Banned
Link to Source:
I doubt it was me, But I stand corrected. Nice to know I guess. See....You taught me something.
P.S. I think seafoam tranny additive would have done it too.
Old 12-01-2006, 07:46 PM
But Seafoam REQUIRES draining the Trans.
It is merely advised when adding the Diff. Additive
Old 12-01-2006, 07:48 PM
Budfreak's Avatar
Banned
I'm just a stickler for doing things the traditional way. If it belongs in a diff, I put it in a diff. If my tranny is binding, I buy tranny additive. I've had good luck with tranny honey in the past too. Good stuff.
