Old 11-25-2006, 02:37 PM
ARED 97's Avatar
ARED 97 ARED 97 is offline
Oil Light at idle
Just recently my oil light has been coming on at idle when the car is warmed up. Tach shows around 500rpm when light comes on. Is there an idle adjustment somewhere? The light goes out with just a little more throttle. Anybody have similar experience? Only change was a new PVC valve and that was weeks before the light started. Where should I BE LOOKING? THANKS IN ADVANCE !!!
Old 11-25-2006, 05:07 PM
dwd1985 dwd1985 is offline
There is no real idle adjustment, it is automatically controlled by the ECU. some people will claim you can re-adjust the TPS or the throttle cables, but eventually, the ECU will reset it to the proper factory setting of 610 RPMs at idle. I would reccomend checking the oil level, add some more if needed, and see what happens.
Old 11-25-2006, 05:09 PM
Archer999's Avatar
Archer999 Archer999 is offline
place to start
Check your oil. Just a thought.
Old 11-25-2006, 05:23 PM
ARED 97's Avatar
Thumbs up Oil light at idle
Checked oil level when light first came on, my first thought too, oil level ok!
Old 11-25-2006, 05:49 PM
ShiuludeSVX's Avatar
Pump
I would be thinking about the Oil Pump myself.
So, with a bit of throttle it goes away. Oh yeah, I would start asking the Maniachanics about that one.
Or just pull the pan, and check the pickup, and screen if it has one.
Even a clogged filter. More demand = more pressure under throttle, and then the light would go away.
Sounds logical to me.
$.02
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Speedklix's Avatar
Locker Link Solution
How many miles? I'm guessing it is a 97? or is it older?
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 11-25-2006, 07:31 PM
ARED 97's Avatar
Oil light at idle
Yep, good guess .... a red 97 --155,000 miles, runs great! Clogged oil filter seems plausible, about due for a change, will try that! Oil pump possible, although I think when cold would work pump more and light doesn't go on at idle until car has warmed up. Thanks, any other suggestions appreciated.
Old 11-26-2006, 09:39 AM
rallyingrob's Avatar
rallyingrob rallyingrob is offline
when the oil is warm/thin it can suffer a loss of pressurization through the main bearings........i'm still extremely new to the subey way, but all i've ever learned through v-8's indicates worn bearings ..........
i'm too svxy for my car
rob
92 ebony 4.44's rock !!
Old 11-26-2006, 10:10 AM
Bearings
That's very possible also, although I would hope otherwise.
If there is a substantial knock when the Engine first starts up, then maybe the Bearings.
I would try the filter, and maybe ungunk the bottom of the pan first.
Try some of the Motor Flush from Marvel before your next oil change.
The Worm
_______________
No Mods, 33K Miles
Old 11-26-2006, 10:17 AM
ARED 97's Avatar
Oil Light at idle
No knock at startup, so I'm hoping too! Marvel Motorflush sounds like a good idea also, will try that and see what results. Thanks all!.... any other sugggestions appreciated !
1997 Polo Green SVX LSI #316 49,000, garage queen, aka "The Green Queen" 1997 Brilliant Red SVX LSI #200, 167,000, daily driver, aka"Rosie's Rocket I" 1997 Brilliant Red SVX LSI#234, 106,000, summer driver, aka"Rosie's Rocket II"
1988 Red & White Silverado, aka "The Hauler"
2000 GRAND MARQUIS LS w/ handling package, aka "BIG BLUE"
1988 Mazda RX7 Convertible, aka " Lil Blue "
Old 11-26-2006, 10:31 AM
Speedklix's Avatar
I had the light flicker ever so often and a ticking issue. When I resealed the oil pan I also put a new o ring in the sump... I've seen neither since. (even though it now resides in someone's basement)
Do you know for sure what oil is in it?
-Mike
[SIGPIC][/SIGPIC]
Old 11-26-2006, 02:47 PM
Oil light?
It may just be the oil light switch.
I would replace that before going any further. It is on top of the engine at the front, between the alternaton and the power steering pump.
Old 11-26-2006, 03:08 PM
Indication is dependent on the operation of a simple pressure switch, located at the front of the engine. This switch could be faulty i.e. slightly out of calibration. It should not be too expensive to replace.
All in all, the only way you can be sure, other than experimenting by replacing the switch, is to do a proper test on oil pressure, by connecting a calibrated oil gauge. This would certainly put your mind at rest. Meantime do not panic as you have oil pressure under operating conditions and the problem does not from all accounts, for the moment appear too serious.
Old 11-27-2006, 09:00 AM
Trevor has it right... I would also check to be sure the connector is on the oil pressure switch. also check that the wires are not corroded
