Old 11-25-2006, 01:15 PM
dash lighting up!
Ok so just yesterday I got the "christmas tree" effect almost all the lights lit up (power steering, battery, stom lamp, ABS and maybe one other), when i would press the brake the lights would go out (most of the time) now the lights are on all the time. I replaced my alternator with a known good one, lights were still on and i also replaced the battery, lights still came on...any idea?
Old 11-25-2006, 01:37 PM
Crazypolo95 Crazypolo95 is offline
95pologreen
Send a message via AIM to Crazypolo95
That should happen with a new alternator. When my dad got a new alternator it said that he was going 100 on a death stop. It should go away in some three or five mins tops. If not that then there is something really jack up with your car
Old 11-25-2006, 01:41 PM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
Check the MAF sensor, my '92 had been doing this and my first thoughts were alternator and battery, but the MAF is what ended up fixing it.
dustin
-Dustin
Old 11-25-2006, 06:11 PM
thanks dustin i'll try that out tomorrow, will keep posted...
Old 11-26-2006, 08:57 AM
update
well i replaced the MAF sensor and the dash lights are still lighting up, so far i've replaced the alternator, battery, and now MAF sensor...i am at a loss, any other thoughts?
Old 11-26-2006, 11:06 AM
odepaj's Avatar
Killer of threads
Do you get any engine codes? Check wires, since you said the lights would go out when you hit the brakes it could be a wire that is moving around and shorting or something.
dustin
-Dustin
Old 11-26-2006, 11:55 AM
crotchrocketony's Avatar
crotchrocketony crotchrocketony is offline
I would run by your local auto zone or some parts store like it and have them check your charging system. I know you say the alt is known to be good, but I would dubble check it. I had the same deal and i replaced the alt with a known good used one and it still did it. then I put a autozone reman one on and it still didi it and on the 3rd try I got a good one and cured the problem. thoes stores check youe system for free so it wouldnt hurt to do it just to make sure
Tony
1992 SVX black/redish 62k awd, rims, brakes..and a few add ons for extra HPs
Old 11-26-2006, 02:44 PM
As I have often explained, a faulty alternator diode will result in alternating current being induced on the DC circuits and bypassing blocking diodes in the fault lamp circuits.
I have not tried this simple test, but it should work in the absence of a scope for a proper test. Set a multimeter to the AC volts range and a scale covering 12 volts. Apply a test across the battery and if you get a reading, this should show the presence of alternating current, proving an alternator fault.
A second method also untried, would be to connect two capacitors of around say 100 mfds and 16v or more working voltage, in series with both leads to a pair of headphones. With the capacitors across the battery, listen for an AC noise from the alternator when running and at engine speed.
N.B. Directly connecting the headphones will destroy their windings and it is for this reason that I suggest two capacitors by way of a safety measure. A cheap miniature earphone or headphones of the $2 shop sort will do the trick. Only those who appreciate what is being attempted should try this experiment.
Old 11-26-2006, 11:48 PM
vernemusso vernemusso is offline
Send a message via Yahoo to vernemusso
Same problem with the dash lights
What a stroke of luck ( I guess ). I'm having the same problem with the dash lights ( engine light does not come on ) My original alternator was rebuilt to the tune of 225, a new battery was installed and when I first started it, the lights did not come on. When I took it for a test drive, the lights came back on within 5 miles so the alternator was removed and retested. It tested OK on the bench so it was installed once again. My car also needs brakes and I'm wondering if the ABS light would come on? I've yet to try Trevor's idea of measuring for alternating current which is the most intelligent idea yet. ( Love your country Trevor and thank you for your post ) I checked my invoice and everything except the diode was replaced so maybe this is actually the problem. Is the diode integrated to another part or is it free standing? I'll report on Trevor's suggestion tomorrow after the experiment.
Old 11-27-2006, 12:00 AM
The diode (rectifier bridge) and voltage regulator are located inside the alternator. The shop should have checked these circuits when the alternator was rebuilt. It it passed their inspection prior to leaving the shop, I would assume these circuits were functioning properly.
Here is a link for understanding the alternator
http://www.autoshop101.com/forms/alt_bwoh.pdf
Old 11-27-2006, 12:57 AM
If you visit there could be a bed waiting.
Check on the site svxcess suggests before experimenting, as this will give you a good idea of all that is involved.
It is quite possible that the diode network was not checked properly in respect of an overhauled unit, as knowledge and care is involved.
Best of luck, Trevor.
Old 11-27-2006, 02:26 AM
dash lights
Visited NJ back in '78/'79 spent 2 months on the north is. and 2 on the south.
Favorite place was Nelson. Honesty was rampant then...........is it now? And if I could, I'd go back in an instant. But this thread is about dash lights .........not how friendly the Kiwis are, with crystal blue lakes tempting you with prize fishing, towering alpine vistas, geysers spewing forth the earth's innards,
Maoris performing the Haka (sp), the song of the tui bird, the quiet manner that the Kiwis are known for, the beautiful flowering pahutakawa tree that will or is in bloom now..............I'd better stop ! Thank you again for your help and your knowledge. If only those that actually work in this field had half of your knowledge. We can only dream.......................
Old 11-27-2006, 03:30 AM
Favorite place was Nelson. Honesty was rampant then...........is it now? ...................
Sadly no. One must now lock all doors. Even so a better place than most.
Comments much appreciated. Cheers. (N.B. Saving space in case this gets kicked out of technical. )
Old 11-27-2006, 02:51 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
When I had this problem, the alternator checked out fine on a bench test but not in the car! The shop changed the regulator and the end plug that connects to the alternator. Almost a year now with no problems.
Old 11-28-2006, 01:52 PM
more input the better
Thanks Dannmarr for your input but in my case, everything except the diode was replaced, hence, the rather expensive bill or maybe i just got hosed ! Trevor's suggestion of testing for AC will have to wait as the weather has turned sour.
