Old 11-24-2006, 10:56 AM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
Tie rod replacement
How do you replace the ball joiint type thing at the end of the tie rods? does the entire tie rod have to be replaced or can you replace just the ball joint type thing?
dustin
-Dustin
Old 11-25-2006, 10:37 AM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
the intire tie rod must be replaced and the car needs to be aligned... just loosen up the jam nut and screw the tierod off make sure to count how many turns it takes to get it off so that the alignment will be close enough when you put the new tie rod on you can drive it somewhere to be aligned.
- John
