Old 11-10-2006, 07:33 PM
rallyingrob's Avatar
rallyingrob rallyingrob is offline
check engine light at idle goes out with throttle
i FINALLY have the beastie up and running (WOOHOOOOO!!!)
4.44's are great...zero to losing license stupidly easy in this thing........ahem
lol
my question is:
the check engine light is on at idle
but goes out with even 1/8 " of throttle pedal input and stays out til the engine is at idle again (zero throttle input)
i'm thinking maybe gummed up air bleeds (or bypasses or whatever subaru wants to call them) in the throttle butterflies?
or...........? an engine vacuum situation? all vacuum lines/fittings appear in good repair ( i know........appearances can be deceiving...!!
when starting the car from cold, the idle is rather higher than i am used to in an injected car (1600'ish rpms) and then comes down over the next few minutes as car warms up...it acts just like a choked carb'd car from the bad ole days.....
is this normal?
ps......the power light blinks the requisite 16 times at start-up, but i havent had time to check code(s) yet.........
i'm too svxy for my car
rob
92 ebony 4.44's rock !!
Old 11-11-2006, 09:44 AM
trieck1232 trieck1232 is offline
Send a message via AIM to trieck1232 Send a message via MSN to trieck1232
what code is it throwing the ce light that is...
---Travis---
Old 11-11-2006, 12:51 PM
sorry, i still havent had time to pull the code(s).......
although i s'pose it could be the tps eh?
rob
Old 11-11-2006, 01:48 PM
it could be a lot of different things
---Travis---
Old 11-11-2006, 02:00 PM
michael's Avatar
michael michael is offline
What Potholes ???
Sounds like the early stages of a bad o2 sensor.
Old 11-13-2006, 07:30 AM
I hope you've pulled both the ECU and TCU codes by now.
Old 11-13-2006, 11:39 AM
i havent been driving the car yet really...one 10 min run round the block was it so far.......(cracked rad upper tank being replaced tomorrow(hopefully)
nope.........still havent had time to pull codes...wifey is adamant the kitchen floor i ripped apart be done first!! LOL
this post was to get an idea of where to begin the search for answers....
i guess the answer is : PULL THE FREAKIN CODES!!!!!
lolol
and then go from there.........!!
rob
