Old 10-15-2006, 12:58 PM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
Today's problem: 24/7 FWD
I finally got my engine running well enough to try a launch to verify that the AWD in my Outback tranny is working. It's not. If I put a FWD fuse in, the FWD light does not come on. The Power light does flash indicating Duty Solenoid C(just like with the SVX trans that came out), but it also doesn't have a resistor behind the battery. I actually noticed this problem before I ran 2 quarts low on ATF due to broken hose two days ago. I guess I'll go check the wiring first. From what I've read, it seems when Solenoid C fails it goes 50/50 and not FWD so I'm hoping its just electrical. But on the bright side, I did only pay $800 for this car.
Stephen
Old 10-15-2006, 01:38 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
sounds like your transfer clutches are smoked
- John
Old 10-15-2006, 02:05 PM
elninoalex's Avatar
Registered Abuser
Unfortunatley, I realize that's a possibility. But doesn't the fact that the FWD bulb doesn't illuminate indicate it could be electrical?
Old 10-17-2006, 10:04 PM
elninoalex's Avatar
Registered Abuser
Is the "FWD" dash light supposed to come with all the other dash lights when you turn the key on?
Old 10-18-2006, 06:40 AM
Suby Fan's Avatar
no its not and sol C can fail closed and cause the car to be in FWD all the time
- John
Old 10-18-2006, 09:29 AM
Subyfan is right... If the solenoid seizes while in an open positions it will cut lie pressure to the transfer clutchs and thus...FWD. So my suggestion is to get a new sol. C nd transfer valve. If thats going to be too expensive, than find a used one...
Old 10-18-2006, 07:45 PM
elninoalex's Avatar
Registered Abuser
Thanks guys. I printed out that 90 page 4eat manual from Lee's locker, so I'm going to try the electrical route first..........that is if I ever stop working.
Old 10-19-2006, 12:46 PM
elninoalex's Avatar
Registered Abuser
Some good news for a change.
I measured resistance on duty solenoid C and it came up as open. But I called the dealer to get the part # for my 97 Outback tranny and there were 3 choices. They determined that it was the one that has the same part # as the SVX. So I can just drop the one in from my spare tranny for only the cost of gaskets.
Stephen
Happy 1000th post to me
