Old 02-13-2006, 05:15 PM
immortal_suby's Avatar
Thread Killah
Originally Posted by Tcat55371
So what does this get you and do all the stock ones crack?
Is this something I should be looking into also? I have a 92
Not to hijack your thread, just asking because I dont know.
The light weight stock size ones theoretically should allow the engine to rev up quicker due to less rotational mass.
The underdrive ones should free up some horsepower by reducing parasitic losses by the power steering, alt., and AC.
You won't feel either gains by the seat of your pants. You probably would not see either even on a dyno.
Replacement with a stock subaru pulley is the safest option because you retain the rubber dampener. There has been quite a debate here and on other forums on whether going to a one piece pulley will eventually destroy your engine. So far we haven't seen any failures.
The one piece construction guarantees you that you don't have another pulley separation like with the stock pulley.
It is common for the stock pulley to let go but not guaranteed. I've seen alot on here breaking over 125k or so but there are also alot of them still running with many more miles than that.
Just keep an eye on yours (listen for squealing on startup or in turns) and if it does break you know your options for replacement.
Locker Link
2015 BRZ Limited 6MT
Old 02-13-2006, 06:19 PM
Myxalplyx's Avatar
XT6 is SVX's Daddy
My car is over 125k so I guess it can be called 'preventive maintenance'. For other folks it would be labelled 'self destruction'.
Kevin Thomas
***R.I.P***
Old 02-21-2006, 07:15 PM
Myxalplyx's Avatar
XT6 is SVX's Daddy
Bomz Pulley Pic and Weight Info
I am posting this post up so that people can get an idea of what the Bomz pulley looks like for the SVX and weight info.
The Bomz pulley weighed in at exactly 1lb. Not even an ounce over.
The pulley is an underdriven unit so it is not for everyone. A disclaimer states that belt sizes may vary slightly but Bomz recommends using the Gates Brand belts.
Alternator/Water Pump Belt - Use Gates K050330 (33 5/8" or 855M).
Air Conditioning Belt - Ultra S Gates K040335 (34" or 860MM).
I need to order these belts because I simply do not have time between work and school this week. Hopefully, I can get them in before this weekend and possibly test them out on the dyno vs the stock units. Stay tuned!
BTW: I just ordered both belts from:
https://ec.kamandirect.com/projectfiles/home.jhtml
Hopefully they'll get to me before the week is out.
Kevin Thomas
***R.I.P***
Old 02-26-2006, 02:28 PM
Myxalplyx's Avatar
XT6 is SVX's Daddy
Just updating some info in case anyone in the future is looking for it. I weighed the stock pulley. It weighed in at 4lbs 13.1oz (I'm sure this is posted up somewhere).
So you get a savings of 3lbs and 13.1oz. Not too bad.
The sizes do not seem that far off. Here are a couple of pics of the stock pulley vs the Ebay Bomz pulley.
Now that I have gotten some practice changing out the pulleys, I can go to the dyno and test them out. Hp/Torque readings may be different than before since I have a different set of wheels on the car. That's all for now.
Kevin Thomas
***R.I.P***
Old 02-27-2006, 05:23 PM
VTsuby
You might lose some power. It has been shown at least on some racing engines that light weight pulley can interfere with the valve train in fact a heavy damper can sometimes make more power. Take the mass out of the flywheel since it is damped by the clutch or lighten the internals.
Old 08-17-2006, 07:44 PM
SomethingElse's Avatar
word words wording
I know this thread is old but are these the correct belts?
Eric
Old 08-17-2006, 09:06 PM
Thread romancer?
I dunno.
Take an OEM belt to a parts store and ask them for one that's an inch or two shorter. That's what I did.
Old 08-18-2006, 09:48 PM
word words wording
so nobody has used them?
Eric
Old 08-19-2006, 02:07 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
My belts were a ***** to find for my underdrive pulley. I had to look everywhere for a belt 1 inch shorter than stock. I don't know who made my pulley, But it came off of Solarsvx's WRX.
Old 08-19-2006, 05:52 PM
word words wording
I used the belts the sheet reccomended that came with the pully but my tensioners are maxed and they are still loose. I went to motorsport warehouse and looked but the belt numbers are wiped out?? Why the @#$& are the numbers suich a big secret?
http://us.st11.yimg.com/us.st.yimg.c..._1912_10288590
Eric
