#31
Solar powered fan that circulates air while parked
<---I hope
#33
*DING* *DING* We have a winnAr!
#35
It's this bad boy here...
No. 16 and 17 in the pic. There were two versions of it, I believe one actually has a cooler of some kind built into it. http://www.subaru-svx.net/photos/files/svxcess/246.jpg Check out the rest of the JDM catalog in svxcess's locker. Last edited by Porter; 06-14-2004 at 06:24 PM. |
#36
Solar power cooling unit
I want one too.
Victor |
#37
Stealing my Thread is not allowed.
See Subject.
#38
Cabin Air filter/solar air filter UPDATE
This is the latest information I got from Subaru Japan/Japan Direct Import Service: Evidentally, these accessories were designed for the JDM market as it seems that the Japanese are very heavy smokers No. 16 is a cabin air cleaner/purifier system. It is hard-wired into the 12V electrical system and works in conjunction with the climate control system. They said it was not too hard to install and would send me translated instructions, if needed. "Cabin Air Cleaner (No. 16) Catalogue says that this cleaner works by the electrical power of car battery. The cabin air cleaner circulates air in the cabin by electrical power of car battery, and cleans dust and odors through a filter in it. This cleaner is controlled by a switch that is installed around driver's seat. it starts working for 5 minutes with Hi-mode linking with the air conditioner; then it is changed to Low-mode automatically. Installation manual is also included in the box, and we heard from Subaru that you can install it easily. (I will translate the manual for you if you purchase this item.) No. 17 is a smaller, less powerful version of No. 16. It is solar powered and can be used on the dash or the rear deck, or both. Details of solar cleaner (No. 17) The catalogue says that the fan for this cleaner works by "solar electrical power", and removes odors from the cabin. After that, the good and light smell of jasmine remains. You should think this equipment as an aromatic. Actually, this equipment has a solar battery in it, and a fan works without any sources of power. But it works only for an aromatic, and doesn't work for the cleaning of air in the cabin. Also, liquid in it has to be purchased once it runs short. You can install this anywhere you prefer because this equipment is fixed by double-sided tape." Quote:
#39
Cool! The guys at SOA were convinced that #17 was an air circulator. I guess it is, in a way of thinking. It's an air circulator with built-in sneezy juice.
#40
The entire alcyone accessories can be found on the SVX section of the japan Direct Import service website.
http://www.mediawars.ne.jp/~kemkem/s...acce/svx01.htm Both of the air filtration systems are still available. The JDM part number for the cabin air filter system (No. 16) is G3015PA000. It was 43,900JPY or $400.00 US The solar filter (No. 17) is K0072YA000. It was 5500JPY or $50.00 US. Japan Direct Import Service charges a minimum commission of 3000 JPY ( $27.00) plus shipping by air express.
#41
Re: Subaru made SVX headlight protectors.
John there's a spoiler on here that looks like its off the Blitzen Legacy ( http://photos.carlist.ie/photos/7686...8435_large.jpg ). That wasn't stock for the SVX? It does look pretty good though.
1992 Subaru SVX LS-L #5045 Dark Teal 1992 Subaru Loyale Wagon Gray (SOLD) 1999 Subaru Impreza 2.5RS Coupe Black Ruby (SOLD) 1969 Subaru 360 Deluxe Ivory White 2005 Subaru Impreza WRX STi World Rally Blue 1993 Subaru Legacy L Wagon Teal Metallic (SOLD) 1998 Subaru Impreza 2.5RS Coupe Rally Blue Pearl [SIGPIC][/SIGPIC] |
#42
1992 Pearl White LS-L "Ruslana" #4946 - 180k on body, 95k on engine. Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1½" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint. †"War doesn't determine who is right, only who is left"† Work to be done: Tinted windows, clear/LED tail lights, tailbar mod, "Power Mode" mod, Supertone horns, clear corners & headlight lenses, 2 pc splitters or custom bumper, Alcyone side skirts, TruSpeed Stage III SVX Intake, Hydra, 4.44 tranny swap, JDM auto folding side mirrors, engine rebuild, super charger, STi seats, bone leather interior /w SVX emblem, dash overhaul, SVX decals, paint (stock color). Total cost?: 22k At least it's going down..
#43
i want JDM floor mats
#44
Would the clear covers stop or slow down the yellowing on our headlights?
#45
Re: lense covers
lol actually im planning to do that on mine. i think looks really nice. im also planning to do them in the tailights
