Ecu Speed Pin
Installing my speed meter. I found a Ecu pin diagram. The speed meter needs a "speed signal wire" will Vehicle speed sensor 2 (B60, 11) work. Looks like the correct 5v signal, just checking.
http://www.subaru-svx.net/forum/atta...6&d=1058575037
1992 SVX- -Drivetrain by BUDFREAK- Green, LS with spoiler, 157,000, ES Swaybar bushings, 9005/6 mod, 2.25' Dual Exhaust, Custom Grounding, Hyperwhite fogs, LED tails, 4.44s, custom Blitz intake, tranny cooler, thats about it, for now... 1997 Chevy 1500 -FOR SALE- 5.7 liter, Z71, 300hp+, still almost 20mpg 1986 Merkur XR4Ti -SOLD- SVO Engine, T3 hybrid turbo, K&N, custom ducting, Initial D painted, 18psi, fastest car for under $1000, ever. |
Yes. That's the one.
It's a 5 volt square wave, the frequency of which is proportional to your speed. Four cycles per revolution of the sensor IIRC.
The speed sender on the gear box works by pulling the voltage supplied low not by supply a wave form from 0 to 5V as was thought before. If you mesure the voltage on the ECU it has power. DOn't know if that helps.
Tony
