Old 11-23-2010, 09:03 AM
Sov13t's Avatar
Sov13t Sov13t is offline
Fuel Pump Died
Warmed up the car this morning, with remote start, while I was getting ready for work... which is 15 minutes of run time. Timer ran out, and the car shut down. Get into the car maybe 10 minutes later and try to start it... nothing. Engine turns over fine, sounds perfectly normal in terms of any mechanical issues.
Started going through troubleshooting... codes are fine, checked all the connections to vital sensors and switches... all are fine. Switched over to Hydra to see if it would at least start... nothing. At this point started to suspect the fuel pump Pressure in the fuel line post fuel filter is not there, I can squeeze the line with my hand... Pressure pre-fuel filter is also the same... non-existent... So... I guess the SVX throws yet another curve ball at me.
Fuel tank is at 95% capacity... and as far as I know replacing the fuel pump requires an empty tank, any suggestions on how to drain the tank and perform this fix out of a parking lot?
Cheers,
-Sov13t.
Subaru SVX 94' Laguna Blue - 8.5 C/R Built Motor, 6spd
Old 11-23-2010, 09:22 AM
Re: Fuel Pump Died
Cheers,
-Sov13t.
Kirill,
The fuel pump is easily accessed through the silver plate (4 philips head screws) in your floor behind your rear seat, under the trunk carpet. You do not need an empty tank.
Old 11-23-2010, 09:30 AM
Sov13t's Avatar
Re: Fuel Pump Died
Copy that, thanks Mike!
Will take a closer look at it once I have more time... the timing couldn't have been better, as always... SVX might be going up for sale soon.
Old 11-27-2010, 02:29 PM
Sov13t's Avatar
Re: Fuel Pump Died
Any suggestions on how to unscrew the fuel cap on top of the tank
Old 11-27-2010, 03:28 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Fuel Pump Died
Hammer and flat blade screwdriver.... tap tap tap
Also did you at least check to make sure there is voltage at the pump with the key on? I would never pull a pump unless I insured it was getting power when it should, and I saved myself a lot of grief. Electrical problems should be eliminated first.
Old 12-06-2010, 06:15 PM
msg115031 msg115031 is offline
Re: Fuel Pump Died
check the #16 fuse in the car
Old 01-05-2011, 07:56 PM
Re: Fuel Pump Died
So how did this go?
Fixed? Pump wasnt the issue? Blew up?
