Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
Old 08-26-2006, 02:23 PM
longassname's Avatar
Just some dude.
Significant Technical Input
ECUtune Stage 2v6 ethanol, e85, flex fuel, turbo, supercharger, force induction
Ok boys and girls, we've got some Stage 3 cars on the road and being put on the road and now I can turn my attention back to what I do: Engine management software.
I know some of you were wondering what "secret" Chris refered to in the Stage 3 thread that I am working on and I see that the topic of E85 has come up in one of Phil's turbo threads. I'm guessing because he knows the "secret" since he lives in a corn state and is one of our guinea pigs. The "secret" is we are replacing the 2nd version of software on our memory adaptors (the 87 octane code, nitrous code, etc) with software for e85. The first version which will be available for purchase is Stage 2v6. We will be testing it this week before shipping but believe it is done.
Both the premium unlead software in the default memory location of 2v6 and the e85 software in the 2nd memory location of 2v6 incorporate a couple of other substantial improvements. In the stage 2v6 software a lot of ignition timing has been moved from the revision table into the primary table. This changes around the way things work. Instead of the ecu having to learn in additional advance now it runs it to begin with and if need be can take it out according to the knock sensors. With this change we see about 5 degrees more ignition advance being utilized very happily through out a wide range of driving conditions on the street. This provides a real performance improvement in all types of driving conditions.
There are two areas of the table which are not normally seen in a stock svx but are now important for a number of mod'ed svx's out there. The above mentioned change to the timing table dramatically changed the shape of the timing table in those areas for HUGE improvements for these modded cars. The two areas are for 1) of course, svx"ii with forced induction 2)svx'ii with manual transmissions.
There is now an appropriate amount of timing at low rpms to maintian engine operation while shifting a manual transmission. The prior lack is a likely culprit for stalling issues many svx'ii with manual transmission conversions have encountered. There is now also an appropriate amount of ignition timing for those running higher loads than factory. Performance with forced induction etc are hugely improved.
Old 08-26-2006, 06:02 PM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
Michael:
That sounds really good. Can't wait to make the upgrade. You have created any army of addicts out there who faithfully line up for your latest enhancement. count me as one. I guess this will be the fourth one of your chips I have had in my car.
____________________________________________
95 LS-i Red, 31,xxx; bone stock for now; Daily Driver
94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light,
2017 Subaru Forester XT, metallic dark gray, 29,xxx
2005 Porsche 911 Turbo S Cabrio, 24,xxx
2006 Subaru Outback LL Bean, 166,xxx sold
92 LSL Dark Teal, Smallcar Shift Kit - sold
Old 08-26-2006, 07:50 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
Send a message via AIM to gest24
Sounds like a good thing to try out and see some numbers on the Dyno over 2V5. How do you do the "upgrade" in software for current customers?
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs!
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
88 XT6(regret the day I left her behind)
socaleuro.com They like the flat 6...
Check My New Homepage..
Old 08-26-2006, 08:03 PM
Bobb Bobb is offline
E85
Hi LAN, Its my understanding that if a vehicle is not piumbed to take E85 in the fuel system that E85 will "eat" the hoses, gaskets, etc. And because of the reduced BTU's in E85 you will get about 30% less fuel mileage. Also I don't know what effect E85 will have, long term, on our plastic gas tanks. Take card, BOBB
Old 08-26-2006, 08:42 PM
Just some dude.
It's my understanding that after the fuel shortages in the late 70's when they did mix ethanol into the gasoline despite vehicles having some materials with incompatiblities in them that in the 80's US regulations were modified requiring auto manufacturers to make all vehicles for US markets ethanol compatible. It's probably an excellent idea to change those antique hoses anyway. Both Dayco and Gates fuel injector hose are multi fuel compatible--they have been for over a year.
On the note of probable fuel efficiency with E85 in a propperly tuned SVX: It does require about 30% more E85 by volume to attain the propper afr; however, that does not mean that your fuel efficiency will go down 30%. I think it's interesting and worth pointing out that with the stage 1v4 software we increased the fuel injected by 12% and didn't see any decrease in fuel economy because the resultant power improvement gave us something back for our 12%. It's not exactly the same situation with the E85 because 30% is a lot more than 12% and because that 30% is consistent even under light loads; however, we can expect the significant performance improvements we will see with E85 to lessen the impact on mileage very nicely.
Really what it comes down to in my mind is that the SVX engine is barely able to operate with US premium unleaded and would really prefer a higher octane fuel. E85 is 105 octane and is basically a better fuel for the SVX in every way. In fact the higher mass of E85 injected benifits performance by increasing cooling. The increased mass caries the heat from the combustion chamber out the exhaust.
Besides being superior for a stock svx engine the burning characteristics and increased mass of the E85 fuel charge should prove an amazing improvement for forced induction which has even higher dynamic compression.
Old 08-26-2006, 08:45 PM
Just some dude.
Having given my opinion on E85 and the SVX I want to make clear that is just my opinion. The stage 2v6 software should not be considered an e85 conversion kit. It is as all of our products are for off road use only and it is the purchaser's responsibility to determine the applicability and combatibility of it for their application.
Old 08-26-2006, 08:52 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Micheal,
Great news! Have you been following the "Cam Lobes" thread? Do you see any issues with running the 2V6 chip with the cams we're looking at for NA applications? Gest24's dyno runs with the stage 1 intake cams, 2v5 chip and z32 MAF looked pretty good, other than being a little lean (which I'd attibute to the use of the stock fpr). Other than the change in the timing table, are there any AFR-related changes?.
-Bill (looking forward to 2v6'dom!)
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-27-2006, 09:41 AM
mikecg's Avatar
mikecg mikecg is offline
Send a message via AIM to mikecg Send a message via Yahoo to mikecg
I thought I had read somewhere that switching a car to E85 required more than just reprograming the ECU. I thought it rquired a complete change of a majority of the fuel system components. It was my understanding that E85 was corrosive and would slowly damage a standard tank, fuel lines, injectors, ect. and damage rubber seals.
Old 08-28-2006, 02:28 AM
drivemusicnow's Avatar
drivemusicnow drivemusicnow is offline
Poor College Racer
Send a message via AIM to drivemusicnow
I'm pretty sure that LAN just answered all of your questions but I'll give a go as well.
For the most part, any car produced after 1985-ish should have a fuel system capable of handling E85... In some states for almost 30 years "E10" has been used, which is just 10% ethanol, 90% "gas"... E85 is obviously 85% ethanol... Alcohol is known to be corrosive towards some rubber, however I am fairly sure that the difference in part life would be slight at best.
Obviously niether LAN or I can guarantee that it won't cause some random gasket to fail, however as this "conversion" is becoming common in the automotive world, i think it is safe to say that you would be fine using the stock system with E85...
on another note, yes, fuel mileage does decrease by 30%, but in some areas E85 is 20-50% cheaper than gasoline. Typically most people find that it equals out in the end, neither gaining nor losing miles per dollar.
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 08-28-2006, 03:11 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Uh, y'all are absolutely wrong regarding E85. Vehicles that are rated to use it have vast differences. Ethanol is highly corrosive and more than a few rubber hoses are required. The metallurgy of the entire engine is different.
The 'gasohol' of the '70s and '80s was never supposed to exceed 3-7%, yet many distributors kept adding more until they began receiving complaints. Then they backed it down a point or two but even that was still enough to cause problems. Usually they ended up around 9-11%. That was enough to eat the zinc from carburetors, turning them into junk. Carbs were made from base metal with zinc which filled the pores. Ethanol/methanol attacked the zinc and made the carbs porous.
Now imagine what 85% ethanol is going to do to pistons, camshafts, etc. Hoses will be the least of your problems.
Old 09-18-2006, 10:01 PM
gest24's Avatar
#1 6MT In Cali
Just got back from cruising around SD. The new version is nice. Snappy and quick. The dyno shop I usually go to was closed so I'll have to try another day to get dyno time and see how the new plots look.
My only issue was with the isis valve. I removed the bypass that Tom and I put on and replaced it with a straight piece of hose. But then the car was idling at 3K. Is my isis valve messed up from the bypass or do I need a check valve in the hose?
RIP
84 VW Scirocco
02 WRX
Old 09-18-2006, 10:10 PM
Just some dude.
I think you mean IAC valve (idle air control valve) which I doubt is broken. This is just a guess but I am guessing tom bypassed the cold air bypass valve and put your little ballcock device in the middle of a hose going from the outlet on the snorkus and the inlet on the throttle body. It sounds like you just made that a straight hose going from the snorkus to the throttle body. That will give you way too much air at idle. The hose from the snorkus should go to the cold air bypass valve and then a hose from the cold air bypass valve should go to the throttle body. The cold air bypass valve is underneath the manifold on the driver's side.
Old 09-18-2006, 10:32 PM
gest24's Avatar
#1 6MT In Cali
Gotcha, makes sense... I didn't pay attention when we took the hoses off. But other than that, the new software is awesome!
RIP
84 VW Scirocco
02 WRX
Old 09-24-2006, 01:39 PM
Just some dude.
Have you fixed your hoses yet?
Old 09-24-2006, 01:44 PM
gest24's Avatar
#1 6MT In Cali
I've been super busy with work and getting my old tranny packed up and ready to ship. I plan on putting her up on a stand this week to check some things underneith and I'll fix the hoses then.
Does anyone happen to have a picture of the Cold Start valve?
Other than that I love the new chip! My fiance even noticed a difference in the car, lol.
RIP
84 VW Scirocco
02 WRX
