Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Transmission and Drivetrain
Old 08-18-2012, 10:12 AM
longassname's Avatar
Just some dude.
Significant Technical Input
JDM driveline swap
Ok, so we've all heard that there's some weird law in Japan that they have to scrap their cars after 60K miles or something weird like that and we've all seen the ebay auctions for JDM SVX engines with pictures of eg33's complete with vtd 4eat transmissions and all the accessories snatched out JDM SVX's complete and strapped to a skid.
Well, I called up one of those guys and bought one as pictured. I've gone through mine and went to some pains to take some pictures to show the differences in the jdm and us market parts and explain exactly what I got so that anyone else who might want to do this will know what to expect. I will also give you the apparantly top secret to others part numbers for the mounts and sources for matching parts so you can actually pull this off.
First off, the guys selling the svx powerlines don't have the matching control units or rear ends so you will have to source those seperately. You will need:
1)JDM ECU (engine control unit)
2)JDM TCU (transmission control unit)
3)3.7 ratio vlsd rear end
I got my 3.7 limited slip dif from an 06 wrx with manual transmission. I opened it up to check the gears to verify it is a 3.7 and it is. It is clearly stamped 37:10 on the ring gear meaning the ring gear has 37 teeth and the pinion has 10.
http://www.ecutune.com/posts/jdm/DSC_9085.JPG
http://www.ecutune.com/posts/jdm/DSC_9088.JPG
Old 08-18-2012, 10:24 AM
Just some dude.
Re: JDM driveline swap
Ok, so you get an engine and transmission still bolted together with all the accessories still bolted to them which they snatch out of a Japanese SVX as a whole and strap to a skid--in my case a palat with a sheet of plywood thrown on it so the whole thing would fit. They do not guarantee that any of the accessories or covers etc will be good. Of course some of these things get broken during transport. The little steel shroud on the output of my transmisison was a little dented but nothing else on the transmission was broken. On the engine the following were broken:
1)left and right front and back timing belt covers
2)drivers timing belt pulley
3)drivers valve cover
4)power steering pulley
5)drivers exhaust manifold
6)throttle body
Fortunately, I had replacements for all of these things on hand. The JDM passenger exhaust manifold is different because it doesn't have EGR but the drivers exhaust manifold is the same. The JDM throttle body doesn't have the two vacuum connections on the top but you can just cap them on the US throttle body with good vinyl caps.
Old 08-18-2012, 10:35 AM
Just some dude.
So..... into the vtd transmission.
The transmission itself is the same as the US part. All of the differences are in the extension housing. The exception to this is the Japanese seem to put more loving care into the assembly of their own stuff than they do ours. There are paint marks from gear matching and hand assembly checks all over this thing.
Here's a picture of the vtd extension housing.
http://www.ecutune.com/posts/jdm/DSC_9012.JPG
open it up and you find the vtd:
http://www.ecutune.com/posts/jdm/DSC_9015.JPG
pull it out and you have a 4eat just like any us model
http://www.ecutune.com/posts/jdm/DSC_9037.JPG
skipping forward to when i put it back together and we have a vtd again
http://www.ecutune.com/posts/jdm/DSC_9039.JPG
transfer clutch frictions going back in
http://www.ecutune.com/posts/jdm/DSC_9046.JPG
output shaft put on
http://www.ecutune.com/posts/jdm/DSC_9051.JPG
rebuilt jdm transmission closed back
http://www.ecutune.com/posts/jdm/DSC_9060.JPG
Last edited by longassname; 08-18-2012 at 10:37 AM. Reason: changed img tags to url tags
Old 08-18-2012, 11:00 AM
Just some dude.
The transmission itself was in better condition than a US SVX transmission would be in but with 60k miles on it without an ECUtune TCU the high clutch was starting to fail.
The photo isn't so great but most of the high clutch frictions were worn smooth on one or both sides. This transmission probably would have driven fine but was on the way out.
http://www.ecutune.com/posts/jdm/DSC_9025.JPG
The brake band was in pretty good shape--just starting to deteriorate a little at the ends which is where they always go bad first. It would have lasted longer than the high clutch.
http://www.ecutune.com/posts/jdm/DSC_9021.JPG
The "filter" which as I have posted previously is really just a screen was the original "filter" from when the transmission was built and was still nice and clean. I didn't touch it. These "filters" don't go bad and I'm not doing anything to this valve body.
http://www.ecutune.com/posts/jdm/DSC_9033.JPG
I also replaced the forward clutch, over running clutch, and reverse clutch frictions. I upgraded the high clutch pack with the special thing I do and upgraded the brake band. Of course, I closed it up with all new gaskets and crush washers. I'm re-using all the externals and torque converter.
http://www.ecutune.com/posts/jdm/DSC_9080.JPG
So to summarize: If I were to have thrown this transmission in without rebuilding it it would have worked and with an ECUtune TCU it may have worked for a good ammount of time but it really was time for a new high clutch and brake band--everything else I just did because I can.
Old 08-18-2012, 11:08 AM
Just some dude.
The vtd transmission uses different rear mounts than the US. I don't speak japanese but the parts are the same as for the australian or uk transmissions and they fortuntely speak english. My transmission had one good rear mount on it which you will see as very shiny because I just sprayed it with mercury phantom black spray paint. I had an Australian customer of mind order me the other mount and the stopper that goes on the cross member from his local dealership for me. The crossmember is the same.
the mount he got me: 41022pa120
http://www.ecutune.com/posts/jdm/DSC_9063.JPG
the stopper that goes on the cross member:41022pa130
http://www.ecutune.com/posts/jdm/DSC_9064.JPG
the mounts installed on the transmission and the stopper installed on the crossmember:
http://www.ecutune.com/posts/jdm/DSC_9071.JPG
If I remember correctly the other rear mount was part number 41022pa110
Old 08-18-2012, 11:30 AM
Just some dude.
I wanted to start with new head gaskets etc so I dug into the engine as well. The first thing I did was start pulling the fuel injectors out assuming they would be gummed up with dried fuel and i was going to send them out to be cleaned and flow tested. I pulled one out and it was the cleanest fuel injector I've ever seen. I pulled a second one out and was super clean too. I then used a couple wire leads hooked up to a flashlight I had handy with about 7 volts of juice to test all the injectors in the fuel rails and they all sounded great. It appears the Japanese guys hook the motors up to a fuel injector cleaning system to remove all traces of fuel from the fuel system before shipping. This is probably required by regulations so you could expect the same if you got a jdm engine
http://www.ecutune.com/posts/jdm/DSC_9113.JPG
With a valve cover off the next thing I noticed was how clean everything under the valve cover was. Either they have better quality oil or better quality oil filters over there or both.
http://www.ecutune.com/posts/jdm/DSC_9122.JPG
While replacing the head gaskets you can see the mythical good SVX motor mounts in this picture. Yes, this engine actually has good OE motor mounts. I've never seen one before.
http://www.ecutune.com/posts/jdm/DSC_9123.JPG
The jdm engines do not use EGR. The intake manifold still has the passageways in the casting but they use a solid plug that goes all the way threw where we just have caps underneath. This blocks off the passageways in the JDM manifold. The JDM fuel lines are different--absent of the hard lines for the vacuum lines for egr.
http://www.ecutune.com/posts/jdm/DSC_9208.JPG
http://www.ecutune.com/posts/jdm/DSC_9211.JPG
And here's the whole thing put back together with loving care and new gaskets and seals and timing components and covers and the valve covers and driver's exhaust manifold off of my last engine.
http://www.ecutune.com/posts/jdm/DSC_9219.JPG
I'm going to be busy for the next week and a half but will install it all at first chance.
Old 01-23-2014, 08:48 AM
Just some dude.
Here E,
I put pictures when I covered the actual work in the begining of the thread. The mpt, extension housing, and mounts on a US transmission could be replaced with the VTD parts with the transmission still in the car. I don't remember for sure if the harness and speed sensor are different or not. I think they are in which case you would probably have to cut off the us speed sensor and connect up the jdm sensor or get a jdm harness.
output shaft put on
Old 01-24-2014, 02:32 PM
'E''s Avatar
'E' 'E' is offline
Ok, I have 7 of these gearboxes lying around
92 pearl SVX about to revive
92 Black 4ws (Jap spec) SVX
93 black SVX
93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear
95 bright red SVX
96 emerald pearl SVX about to revive
Old 01-24-2014, 07:17 PM
Just some dude.
What about TCUs?
Old 08-19-2012, 01:07 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
6)throttle body
LAN,
Looks like they dropped the engine on the driver's side? Was the valve cover just cracked?
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-19-2012, 01:28 PM
Just some dude.
It wasn't dropped. Just banged into something/somethings. The valve cover had a chip out of its front edge.
Originally Posted by SVXRide View Post
LAN,
Bill
