Wiring between ECU & enviro system.
As part of the new install of the Wolf ECU we need to find out how the ECU talks to the enviro system, it appears to have to data wires but the manual doesn't tell us anything.
Can anyone shed some light on this one please. Tony
Re: Wiring between ECU & enviro system.
Hi Tony,
It is not something I have really investigated. I know that the A/C signals the ECU when the clutch is engaged so that the ECU can adjust the idle speed to compensate for the increased loading on the engine. I have seen this in the ECU software. I believe there is also a signal in the other direction from the ECU to the A/C to shut off the A/C at WOT for better acceleration. I don't think the wires carry "data" in the computer sense of the word, just simple on/off signals. I keep thinking that I've seen something about it in the service manual. I'll check this weekend and get back to you. Phil.
The computer will override the A/C on request also if the coolant temperature is above a set point, if the rpm is too low, and at wide open as already mentioned. I second the assumption that the wire is just either on/off signal, most are this way.
I don't have my FSM handy but many vehicles in fact use the ECM to actually switch on the Magnet clutch relay based on a "a/c on" request from the climate amplifier, so it may operate backwards from what has been suggested, but I am not sure. A wiring diagram for the a/c circuit would reveal this if it was the case. Also, the cooling fans are switched on by a pressure switch in the a/c hose. This pressure switch may have an interaction with the ECU so that it can help decide fan speed (Hi, med low) depending on a combination of the engine coolant temp and the position of the high pressure switch. (for example, engine temp low, high pressure switch on-> fan med and, conversely, high pressure switch on coolant temp high -> fans high). These are a couple guesses as to what is being communicated, I am curious to this as well and plan on looking at the diagrams tomorrow as my car is currently at the shop and the manuals are in the seat
2007 GS 450h-Active Stabilizer/Radar cruise 1994 L Blue 3.70 VTD ASE Master Automobile ASE Advanced Level Specialist Toyota Master Diagnostic Technician (former life) Last edited by NiftySVX; 08-13-2009 at 09:59 PM. Reason: addition |
The AC compressor is a able to be adjusted as it is a variable rate compressor the ECU turns the clutch on and off but the Enviro unit controls the load. The ECU does tell it a number of things such as to unload when the car is a full power etc.
It seems that I may have to put a scope on it to find out the real story, kind of feel its a lot more complicated then I orignally thought. Tony
I know this doesn't help much, but several years ago, I was doing some work on a JDM SVX owned by a friend of mine. I found the wiring between the ECU and the A/C had been modified by the previous owner. But I never figured out why. This is what I posted at the time.
Thanks Phil,
