Tire rotation problem
Isn't it always te simple things that get you in trouble?
As I may have mentioned, I did tire rotations and oil changes on both the SVX and Justy on Sunday. The SVX is probably okay - although I have to admit I haven't driven it. The Justy I drove to work today for the first time this week. It's drifting to the right pretty severely. All I did was rotate the tires and change the oil - WTF did I DO???
Hit a pot hole sometime ago I guess. Time for a wheel alignment. Eh?
Car drove straight before tire rotation. Car does not drive straight after tire rotation. But, you're probably right - the only thing to do is take it to be aligned.
Rotation
Hi Nick, Just for fun, put the tires back where they were and see what happens. could be a bad belt on one tire or something not suspension related. Hope its something simple. Take care, BOBB
It does sound like the alignment is out, and the tires took a set. You should definitely have the alignment checked. Even after the alignment gets reset, the car will still pull until the tires take a new set to the corrected alignment.
First, you can eliminate oil change as a suspect for drifiting problem. It is not
Second, you should check tire pressure and wear patterns on you tires. A bad tire can pull to a side quite dramatically and its position (front/back) can affect the pull as well. |
'It's a Justy - there's not a lot of air in a 12in tire to leak out.'
You guys missed it all.
He put the SVX tires on one side of the Justy and vice versa.
Larry III & The Beautiful Naviguesser '19 Tungsten Pearl Outback 3.6R Ltd...."AISHA" '08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU" '07 Gray Diamond Pearl Outback XT Ltd..."AH SO" '05 White Pearl & Silver BAJA Turbo..."AH HA" '97 Bordeaux Pearl SVX LSi..."SUBYDOO" '94 White Pearl SVX LSi..."PEARLY" '92 White Pearl SVX LSL w/touring pkg..."SVXY" '92 Teal SVX LSL w/touring pkg..."ALCYONE" '96 Polo Green LSi ... "MIDORI" '00 Black Dodge VIPER RT-10... "VINNIE" Engineers do it with precision. English teachers are novel lovers. Home: larrysingeriii@comcast.net SVX FEVER, CATCH IT AT A MEET NEAR YOU !! |
Obvious. You should have changed the tires, & rotated the oil.
Anytime. Ron. (Didja' hear about the absent minded park policeman? Yup - mounted his whistle & blew his horse).
Good s**t happened. 69 was worth the wait. '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. |
Our Justy has well over 185,000 miles on it and I don't remember EVER getting an alignment on it. I'm sure it tracks pretty bad but has never really had poorly worn tires.
(SVX is another story)
