Old 03-30-2003, 03:38 PM
Subafreak's Avatar
Superbeast
So the gasket everyone talks about changing is between the housing and the car body. It seems if that was the reason for the condensation that we would also have trunks full of water.
Old 03-30-2003, 05:08 PM
Green1995SVX
When your windows fog up, your car isnt full of water. At least mine isnt.
Mike
Old 03-30-2003, 06:46 PM
Subafreak's Avatar
Superbeast
Usually I'm sooking wet when they fog up.
Old 03-31-2003, 01:06 PM
Noir's Avatar
Noir Noir is offline
re: unfortunately
unfortunately i have the rear taillights condensation syndrome. and unfortunately after a good shower, compartment that holds the spare tire has some water buildup there as well. i looked at the trunk seal and is perfectly fine. i'm looking for the inlet for the water now. you may want to check your spare tire area to see if there are any water leaks.
Old 03-31-2003, 02:52 PM
sfsvx's Avatar
sfsvx sfsvx is offline
Yeah, it's a poodle - so what?
Re: re: unfortunately
Check the power antenna and its associated drain tube.
Dick
1999 Legacy GT 30th Anniversary Edition
2001 Outback Sport
Old 03-31-2003, 03:01 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Re: re: unfortunately
Good call. The hose had been pulled out of the drain in my first SVX. This would result in water collecting inside the left rear fender well.
I also believe a pair of sunroof drains are routed through the C-pillar. Not sure how you can check them, though.
Randy Johnson
Mike Davis -- at Reading VI
