Old 03-17-2003, 12:15 PM
that would be on the bottom right if your under the car looking up at it...also known as the passenger side guess that would of been easier to say...
Old 03-17-2003, 12:17 PM
cbx-man cbx-man is offline
Originally posted by JLittell
Is there a draincock on the bottom of the radiators? Where is it?
It's on the bottom right hand (passenger) side. Unscrew counter-clockwise and the fluid will drain out the little petcock
cbx-man
'92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter
'92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft
'80 Honda CBX in-line 24 valve 6 cylinder
Old 03-19-2003, 08:53 PM
Ovidiu STAN Ovidiu STAN is offline
I tried to change the seals but it was impossible to take out the bolts from the cams ( to remove the timmimng wheels).
How did you kept the cams in place to remove the bolt?
Old 03-19-2003, 09:28 PM
kuoh kuoh is offline
That's what the strap wrench is for. I got a set from Sears. The bolts are on very tight, so you'll probably need some help.
KuoH
