Old 03-11-2003, 01:57 PM
mattski mattski is offline
Christmas lights in March?
Nah, its just my idiot lights coming on suddenly today. Does this sound like the alternator failing? How can I test without going to Autozone (we do not have any nearby, Randy).
My SVX is a 97 with 63k so I can't get codes from the computer.
My extended warranty will cover this so I will probably just take it to the dealer to fix.
Can this be anything else?
Thanks,
Mattski
97 LSi Ebony Pearl 130k Midlife Crisis
93 Legacy Wagon 180k Training Wheels
98 Outback 180k
98 Dodge Durango 120k Ski Bus
A multitude of skis to feed my need to go faster, faster until the thrill of speed overcomes the fear of death.
Old 03-11-2003, 02:19 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Christmas lights in March?
Thanks,
Then, take it to Advance Auto!
You could try checking the connector atop your alternator for corrosion. Also, pull the battery terminals and give 'em a good cleaning. Those are good places to start.
<mumbling> Don't have an Autozone nearby. Bah!
Randy Johnson
Mike Davis -- at Reading VI
Old 03-11-2003, 02:28 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
testing alternator
If you have a multimeter you can test the voltage the alternator is putting out. I THINK it should be around 14.5 volts at 3000 rpm. Just touch the red to the back of the post and then the black to the ground have a friend take it up to 3000rpm (in park of course). New alt. is pricey so you may just want to get it rebuilt should that be the problem. Its a mitsubishi alternator so parts aren't real tough to get. You're looking at $100-150 for a rebuilt. Oh yeah, chances are good it is your alternator. Bad batteries can do the same thing sometimes.
Old 03-11-2003, 06:46 PM
I think the bearings wear out in the alternator. It may not need a full rebuild. A good auto rewind shop should be able to check for you.
Old 03-11-2003, 08:42 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
I've had three SVX alternators rebuilt (from three different cars) and all of them had the stator go open. None of them needed new diodes or regulators. They do change the bearings as a standard rebuild since they have a medium life span.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 03-12-2003, 04:54 AM
LarryIII LarryIII is offline
Matski,
Contact John Shotsky on the Yahoo SVX Group site. He is the moderator and is very very familiar with the SVX electricals.
He is on the west coast.
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 03-12-2003, 06:08 AM
The connection at the alternator was a bit loose. I thightened it and so far no mor Chrismas lights. I did notice that the connection was hot. I had done the alternator mod and there is a 4 gauge wire going directly to the battery. This morning after a 30 minute drive to work I checked the connection and it is still hot. I will take it apart, clean all the contact surfaces and see what happens.
Mattski
98 Outback 180k
Old 03-12-2003, 10:13 AM
Aredubjay's Avatar
"Patience" developed an intermittent starting problem. I checked the "modded" ground (from the neg terminal to the A/C bracket) and it was slightly loose. Tightened it, and no more troubles.
Hope all works out for you.
Randy Johnson
Old 03-12-2003, 02:16 PM
Some alternators have the connection in the form of a bolt running from the inside, but not sure about the SVX, with a lock nut on the outside. If this nut is at all loose the internal connection will be sad and will cause the bolt to heat up.
Randy, if tightening a modded ground fixed the problem this proves that the orginal ground is US. I am sure that half of the mods reported are simply by passing an existing fault in making improvements such as lights not dimming at idle etc. Nothing like this will occur if everything original is 100% and the alternator wiring will remain protected with a fuse, good news in the event of a frontal collision.
