Old 03-09-2003, 10:56 PM
DavieGravy DavieGravy is offline
Question about Axxis pads
Do the Axxis Deluxe Plus brake pads (front) listed here for $27.99 come with shims, do I need to worry about shims, and what is a shim?
Thanks for any help in advance.
Out for good.
Old 03-10-2003, 06:10 AM
Paisan Paisan is offline
Send a message via AIM to Paisan Send a message via Yahoo to Paisan
I have used the Axxis Metalmaster and Ultimates. I don't think they came with shims for either set. The metalmasters are well worth the slightly higher price.
-mike
'14 Touareg TDi | '04 Nissan Armada LE | '14 BRZ
http://AZPInstalls.com
Old 03-10-2003, 08:17 AM
hotshoe50
shim??
Its a thin brass plate and it lives between the pad backing plate and the piston surface...
It reduces both friction and squeeling as the pad moves in relation to the piston....
It should have a light coating of anti-seize compound when reinstalling
Hope this helps
Hotshoe
Old 03-10-2003, 10:39 AM
Thanks guys.
I did some searching and found people complaining that the metalmasters squeek like hec, which is why I wanted to go with the organic pads.
Out for good.
Old 03-10-2003, 11:38 AM
I have been using them, and have not found them to be noisy. Just lucky I guess.
Old 03-10-2003, 04:02 PM
sfsvx's Avatar
sfsvx sfsvx is offline
Yeah, it's a poodle - so what?
Originally posted by DavieGravy
Thanks guys.
Does anybody here know what brake pads are actually made of? When I hear "organic", I think of tofu.
And while I'm asking, what are clutch facings made of?
What IS that stuff?
Dick
1999 Legacy GT 30th Anniversary Edition
2001 Outback Sport
Old 03-10-2003, 06:02 PM
lee lee is offline
What IS that stuff?
Look here for brake pads:
http://www.ebcbrakesuk.com/catalogue...1_dec_2000.pdf
Also may want to look at their product line - the green 6000 series for the Nissan Pathfinder reportedly works for the front pads on an SVX. See the product line & descriptions here:
http://www.ebcbrakesuk.com/catalogue...auto/pads.html
A source of newer OEM type technology (ceramic pads) is for sale at:
https://www.olyonline.com/akebono.htm
and of course Axxis has a very good reputation.
DavieGravy: BTW, normally organic compound brakes have less noise, but also less ultimate stopping power than metallics. I think it's along the lines of "no such thing as a free lunch".
Old 03-10-2003, 08:59 PM
Zero noise with my metalmasters. With the Ultimates I get some grinding noise a little, but not sure why yet.
-mike
Old 03-10-2003, 10:12 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Personally I don't think anyone would find much difference in braking power between semi-mets and organics on the street. The main reason for OEs spec'ing semi-mets was because they reduced the overall size and weight of the braking system to help meet CAFE requirements. The semi-mets allowed them to do so without seriously reducing friciton longevity and fade.
BTW, serpentine belts allowed a weight savings of up to 600# per car. One belt driving all ancillary devices takes up much less space than three or four belts. Not having to lengthen (or widen) the car to accomodate the extra belts saves frame and body weight.
Old 03-10-2003, 11:07 PM
So should go with the organics then? They're quite a bit cheaper than the semi-metallics or ulitmates.
Out for good.
Old 03-11-2003, 12:47 AM
mbtoloczko's Avatar
sans SVX
Re: Question about Axxis pads
The Deluxe Plus pads do not include the shims. If you want to see what the shims look like, point your webbrowser to subaruparts.com, and look up the shims in the SVX parts diagrams. I posted direct links to the diagrams in an earlier thread if you want to search for the links on this website.
There are three shims per side in the front, and two shims per side in the rear.
I've been using the Deluxe Plus pads for about 2 months. I'm very happy with them. Much better than the stock pads. Get the rotors turned while you're at it.
Mychailo
Visit my locker
Old 03-11-2003, 10:18 PM
So what's the verdict? Organic or semimetallic?
Out for good.
Old 03-11-2003, 11:48 PM
mbtoloczko's Avatar
sans SVX
Look at the Axxis pad guide on their website and decide for yourself:
http://www.axxisbrakes.com/technical.htm
Mychailo
Visit my locker
Old 03-12-2003, 11:18 AM
I tried to look at that link ealier but none of the picutres or site content come up, just the background. (Java is enabled)
I even talked to the guy at brakeswherehouse and he said go with the metalmasters or ultimates, as the organics wouldn't give me that great of stopping power. But of course they're going to try and push their high end product over the low end line. I wanted to know if there's "really" a difference. But since people here don't seem to know, apart from a general statement by beav, I'll just get the metalmasters.
Thanks for all the help.
Out for good.
Old 03-12-2003, 12:20 PM
I LOVE my metalmasters!
-mike
