Old 02-22-2003, 07:50 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Unhappy Oil Leak
Noooo, when I idle my car and then move it like 10 minutes later theres a small oil spot on the ground. A few days ago I idled on top of plowed snow and moved it and saw a few anti-freeze drops. You can see a little bit on the top of the belly pan so I guess it dripped through. Does anyone know where the potential leaks could be coming from?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 02-22-2003, 12:32 PM
Subafreak's Avatar
Superbeast
Anywhere? No really for the antifreeze check to make sure the upper radiator hose clamp is tight, or it might be the waterpump.
The oil leaks are usually the cam seals or the front main seal.
Youll have to take the pan off and get under the car to get a better look.
