Old 02-16-2003, 09:47 PM
Paisan Paisan is offline
Send a message via AIM to Paisan Send a message via Yahoo to Paisan
URGENT: Wheel Studs Question
Ok folks. Just my luck one of my wheel studs sheered off at some point and I noticed today. I need to get it replaced before this Friday cause I'm going to the Track.
Here is what I need to know:
Part # for the Stud and Lug Nut.
More importantly, do any of the other scoobies share the same wheel studs or does anyone know if Autozone/Pep Boys carries the studs.
Thanks in advance.
-mike
'14 Touareg TDi | '04 Nissan Armada LE | '14 BRZ
http://AZPInstalls.com
Old 02-16-2003, 10:41 PM
Green1995SVX
Well the lugnut is 28181PA001 and is $7. Im sure you cant get that at autozone etc.
Mike
Old 02-16-2003, 11:04 PM
Yeah I'm more worried about the stud.
-mike
Old 02-16-2003, 11:32 PM
alltrac alltrac is offline
wheel stud
I would use oem first but Bendix is good brand that big o tires uses along with countless others. victor
Old 02-18-2003, 07:02 PM
Just an FYI in case someone does a search in the future and needs the info...
SVX Lug Nut (Proprietary to SVX): PN: 28181PA001
Wheel Stud (RS/SVX/Legacy/others): PN: 28055AA002
Hope this helps someone when doing a search.
Key word search:
Wheel
Stud
Lug Nut
-mike
Old 02-20-2003, 06:00 AM
Just a followup on this.
To do the wheel studs in the front, you need to remove the rotor, and then use a hex-key to loosen the ABS ring so that you can insert the studs from the rear. This had us perplexed for about 5 minutes last night while doing this job.
-mike
Old 02-20-2003, 10:57 AM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
I can swap 3 wheels between 2 SVXes in 5 minutes (including lifting them up on the tiny jacks. Can I be counted as the wheel stud?
L
Lwin M. Maung (Member # 147)
Current SVX: NONE
