Old 02-12-2003, 02:30 AM
CopsodyX
If the POWER light blinks 16 times upon startup...
...and shifts are scarilly buttery smooth and very slippery...what does it mean? (not my lil claret bueaty thank goodness =-)
Thanks in advance.
Old 02-12-2003, 07:10 AM
Tranny problem
The owner's handbook says if this light blinks "for 8 seconds or more" after ignition ON, there may be a problem with the transmission control circuits. See your dealer.
There will probably be a code saying what the problem is. Do a search on code reading, you will be able to find out what the TCU thinks is wrong.
Best of luck.
Old 02-12-2003, 07:44 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Power blinks
Yeah, your getting a code. Do a search of the sight and follow the posted directions to answer the code. It will then tell you what's wrong.
Old 02-12-2003, 09:07 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Procedure is in the "How To" personal locker. Click "personal lockers" at the top of the page, then, scroll down to the How To locker.
Randy Johnson
Mike Davis -- at Reading VI
Old 02-12-2003, 09:51 AM
cbx-man cbx-man is offline
I had 1 long flash followed by 16 quick flashes. And my rear wheel drive wasn't working. Try accelerating hard on wet pavement, around a corner, from a dead stop. If you spin the inside front really bad, then there is a solenoid burned out, which is replaceable. That's all I Know.
cbx-man
'92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter
'92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft
'80 Honda CBX in-line 24 valve 6 cylinder
Old 02-13-2003, 08:48 PM
Did you pull the code yet?
Instructions here
Old 02-13-2003, 10:26 PM
CopsodyX
No i didnt pull the code yet but i will tomorrow...and the RWD isn't working...and the shifting is definitely screwed up...and it wont hold 4th gear...
