Old 02-10-2003, 01:10 PM
Blue94 Blue94 is offline
How does the ABS sensor come out?
I'm in the middle of replacing my rear wheel bearing and am trying to take off the hub and the ABS sensor. But i can't seem to loosen, unscrew, or how ever it may come out, out. I have read that PB is a good lubricant to aid me in this procedure but what is PB?
Thanks
Old 02-10-2003, 02:24 PM
H6'er
Someone (Beav?) had suggested using a chisel to wedge it up.
Tried it on the front and it worked like a charm!
Old 02-10-2003, 04:09 PM
Mr. Pockets's Avatar
Moderator
PB Blaster is a penetrating lubricant. You can get it at your local auto store.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 02-10-2003, 05:43 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
If worse comes to worse you can always follow the other end to the connector and unplug the sensor. It might seem like a pain to do it this way but it's a lot cheaper than $100+ .
alacrity024
BE CAREFUL.
you need to be GENTLE with the ABS sensors or else you'll be greeted with a nice little warning light next time you start the car.
just a warning
-adam
Old 02-10-2003, 06:51 PM
mbtoloczko's Avatar
sans SVX
I think I mentioned a while back that I used a chisel. Perhaps others have also. A narrow sharp chisel worked well for me. Use a little PB Blaster, and then tap the chisel in between the brake backing plate and the ABS sensor mounting tab. Do a little at a time going from one side to the other so as to rock it back and forth as you get the chisel in between the ABS mounting tab and the brake backing plate. Eventually, you should be able to just pull it out.
I suggest that you coat the ABS sensor with some anti-seize when you put it back into the brake backing plate. May make removal easier if you ever have to pull the rear knuckle off again.
Mychailo
Visit my locker
Old 05-01-2003, 03:31 PM
Well it's just not coming out. What would happen if I twisted it? Would I brake anything?
Blue
Old 05-01-2003, 10:41 PM
Never mind Thanks for all your help.
SVX
Old 05-02-2003, 12:52 AM
mbtoloczko's Avatar
sans SVX
Blue
If you can grip it without damaging it, you can certainly try twisting it. However, I think that if you can get a wedge between the ABS sensor plate and the disk brake packing plate, you should be able to get it to come loose.
Mychailo
Visit my locker
