Old 02-08-2003, 10:02 PM
svxjoe's Avatar
svxjoe svxjoe is offline
Only SVX @ UCF (Cool!)
Send a message via AIM to svxjoe
Question OEM Brake Pads. Where?
After Looking through the message archive, I've decided that OEM brake pads is what I'll be going with when it comes time here real soon to replace them.
Now my question is... where can I find these exact OEM brake pads for maybe a reduced price?
I've looked at Subaruparts.com and couldn't see to find any brake pads for the SVX.
Well.....thank-you.
Sincerely,
Joseph
Old 02-08-2003, 10:11 PM
Green1995SVX
http://www.subaruparts.com/diag/?mod...category=262-A
Number 11 on the list.
Mike
Old 02-08-2003, 10:37 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Can you buy them at pepboys for less?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 02-08-2003, 11:24 PM
Green1995SVX
I think he wants the OE pads though.
Mike
Old 02-09-2003, 04:09 AM
Jamsvx's Avatar
Jamsvx Jamsvx is offline
Send a message via ICQ to Jamsvx Send a message via Yahoo to Jamsvx
Any particular reason you want OEM??? When mine die (correction..are dead, need replacing) I am going to try the EBC greenstuff which seem to be highly recommended.
Just throwing an idea in
Cheers
James
1992 charcoal grey SVX:
27 August 2002 to 27 January 2004 - she will be missed
Was back in Sydney for a while but not hot enough so now in Dubai! Has it been that long since I owned SVX-33H!
Old 02-09-2003, 08:19 AM
Tim's Avatar
Tim Tim is offline
Mike
Oh ok. I got worried that I would have to spend that much money on pads
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 02-09-2003, 09:44 AM
Tim's Avatar
Tim Tim is offline
How much are pads from say, pepboys?
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 02-09-2003, 10:02 AM
Every once in a while they offer OEM pads on ebay for about $ 25.00. No one seems to buy them, so I would think that you could pick them up for very close to that.
Old 02-09-2003, 10:51 AM
Tim's Avatar
Tim Tim is offline
Sweet! I need to do my pads soon since they're almost down to nothing.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 02-10-2003, 12:21 AM
mbtoloczko's Avatar
sans SVX
Re: OEM Brake Pads. Where?
What was it in the message archive that convinced you that OEM pads were the way to go? About 2 months ago, I replaced my OEM brake pads with Axxis Deluxe Plus organic pads (as well as having the rotors turned), and I was astounded at the improvement in braking performance. With the OEM pads (which still had 80% of their life), I thought the brake pedal had a mushy feel, and I had to nearly push the pedal to the floor to get the car to stop quickly. With Axxis pads, it takes no effort to get the car to stop quickly, and because I don't have to push hard on the pedal, the brakes have a very nice progressive feel. I'll never use OEM pads again on an SVX.
BTW, when you change out the pads, you might find that most, if not all the anti-squeal shims are gone. Most places don't stock the shims, so you may want to pop off your wheels and have a look to see if the shims are missing well before you start the brake job.
Mychailo
Visit my locker
Old 02-10-2003, 08:52 AM
kuoh kuoh is offline
If your brakes are mushy, you might also consider flushing the brake fluid. Since I started flushing my brake system on a somewhat annual basis, I've noticed more consistent braking performance.
KuoH
Old 02-10-2003, 11:35 AM
mbtoloczko's Avatar
sans SVX
KuoH
Yeah, I should probably bleed the brakes anyhow. Its probably never been done to this car. So, I just ordered a set of Russell Speed Bleeders. :-)
Mychailo
Visit my locker
Old 02-10-2003, 11:52 AM
Paisan Paisan is offline
Send a message via AIM to Paisan Send a message via Yahoo to Paisan
brakewarehouse.com Got some Axxis Metalmasters from them, and they are great!
-mike
'14 Touareg TDi | '04 Nissan Armada LE | '14 BRZ
http://AZPInstalls.com
Old 02-10-2003, 12:52 PM
alia176 alia176 is offline
Hey guys,
Thought I throw in my .02 cents here. Last weekend I finished replacing all front pads with a set from Autozone: Raybestos $35/1 year warranty. Couple of weeks ago, I replaced the rear pads and rotors. Again, the pads were bought from another Foreign auto parts place for $35/set no warrantee. One rear rotor was bought from Murrays auto for $50 another one from Foreign parts place for $75. I'll replace the front rotors too in the near future now that I saw their condition. Both rotors thicknesses were checked using a micrometer and they were identical.
Flushing the brake fluid is a very very good idea when you're doing brake work. When you squeeze the pistons to make more room for the new pads, please open up the bleed screw and drain the old fluid out. Don't send it back into the system. You'll be sick when you see how dirty the old fluid is. I use an old jelly glass bottle with a small hole in the lid. I use an old vacuum hose to drain the fluid into this jar. The beauty of using a glass jar is that you can see the bubbles and the fluid color. I also recommend purchasing a pressure bleeder like Motive power bleeder for around $40. They make this whole thing a one person job and you don't ever have to worry about topping off the reservoir.
Hope this helps some of you.
Ali
'92 Pearlie
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 02-10-2003, 02:09 PM
sfsvx's Avatar
sfsvx sfsvx is offline
Yeah, it's a poodle - so what?
$20 - $70, depending on grade, etc.
I just got some Raybestos semimetallic from them for $40.
Dick
1999 Legacy GT 30th Anniversary Edition
2001 Outback Sport
