Old 02-06-2003, 03:33 PM
JLittell
PVC Valve Help!
I tried the 19mm crowsfoot to try to replace the PVC Valve. It looks as if the 19mm is slipping to the point of stripping the old PCV. It appears that the PVC was never initially changed. I was turning it the correct way. It appears that I won't have any luck with 19mm crowsfoot. Anyone have any luck or suggestions how to get the PVC out by using a box-end wrench? Anyother tool that might work? If you used a box end wrench, how did you have the leverage to get the PVC out? Help!! Anyone with ideas?
Old 02-06-2003, 03:54 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
If worse comes to worse you can always remove the manifold. I'm sure there will be other ideas before you come to that, though.
Old 02-06-2003, 04:26 PM
Mr. Pockets's Avatar
Moderator
I don't know any tricks to get that valve out. But, just for future reference, PVC is a kind of pipe and PCV refers to a system on modern auto engines (positive crankcase ventilation) - of which the valve you want to remove is a part.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
JLittle
Did you see the how to on this operation? Just wondered. The one thing is mentions is (now don't take this wrong, because I have done this before too!!! yep, me ) is to make sure you are turning the wrench the proper direction. Now, before you say of course not, remember that you are using a crows foot (what - not an end wrench!!!) That sometimes throws people off on the proper direction to turn it. Good luck. Nothing is simple is it. A 15 min. job usually turns into a day and a half project!!!
Old 02-06-2003, 05:08 PM
Noir's Avatar
Noir Noir is offline
re: just got a call from mechanic
well, i dunno, like beav said, my mechanic just called and told me that they had to take off the manifold to get to my pcv valve. told me he charged too little for the job, told him i can take my 3 cars somewhere else. i mean he is axing me for 1k and i'm supplying all the parts.
hey i wonder if you can smoke kharma in pvc pipe jay, try it and let me know lol.
Old 02-06-2003, 05:57 PM
You CAN use a box-end wrench to remove the PCV valve. That's how mine was changed. Go out and buy a cheap wrench and have the box-end heated and bent to maybe a 45°-60° (or more) angle. You should then use the wrench in combination with a set of pliers (or vice-grip) to undo the pcv valve.
They really got those things on there tight when they assembled our engines!!
Old 02-07-2003, 10:01 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
I used a closed end to break it loose and a boxed end to take it out. The wrench was unmodified. It was VERY slow going, but, it worked. I looked forever for my crows foot and couldn't find it! Finall, I said, the heck with it, and used the closed/boxed method. After I was finished (expletives deleted) I went to toss my wrench into my tool box. What should I spy, laying right on top, but, my crow's foot. Talk about A) being p!ssed, and B) being "weirded out", all at the same time.
Randy Johnson
Mike Davis -- at Reading VI
Old 02-07-2003, 10:30 AM
svx_commuter's Avatar
Did you try at the bottom of your leg? Caw Caw
Old 02-07-2003, 10:34 AM
Aredubjay's Avatar
Randy Johnson
Old 02-07-2003, 07:18 PM
Actually I meant the closed end of the wrench. The open end would work the same as the crow's foot and if the PCV valve is still original it would probably be rounded off by an open end wrench or crow's foot.
Old 02-07-2003, 10:09 PM
JLittell
I have an old box end wrench that I will have a family friend weld me at approx. 70 degrees. I hope that will work!
