Old 02-04-2003, 04:41 AM
mhl0125 mhl0125 is offline
Send a message via AIM to mhl0125 Send a message via Yahoo to mhl0125
Rear window wiper
My rear winshield wiper does not park itself at the bottom of the window near the rear trunk lip. It rests about six inches up. The switch under the steering wheel for the winter wiper position is in the summer position. Can this be fixed or do the need to replace the entire wiper motor? Thanks for all of your help.
Michael
1994 Barcelona Red SVX-LSI
Two-owner:169K
1995 Emerald Green SVX L AWD
#80 - Custom intake w/cone filter
99K with killer stereo system
2002 Acura MDX-Touring Edition w/navigation
2008 Toyota Prius
1987 Mercedes Benz 560SL
Old 02-04-2003, 05:32 AM
svx_commuter's Avatar
I met a person several weeks ago with the same problem. The rear wiper is easy to fix. Lift up the cap on the arm over the shaft and remove the nut. Pull the wiper arm off and reposition. That will do it. The under dash wiper switch does not work the rear one.
Old 02-07-2003, 07:48 AM
Speedklix's Avatar
Locker Link Solution
Nice. every now and then mine goes back too far. Didn't think the fix was that easy.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
