Old 01-21-2003, 10:39 AM
Noir's Avatar
Noir Noir is offline
RE: transmission
Greetings all,
I found a svx in the salvage yard around here. I was wondering if it was a good idea to buy the transmission and have it rebuilt. Kinda as a spare if mine goes out. I don't know if that's a good idea and how much I should spend for it. I was thinking the same with the front axles. Any good ideas? What else do you recommend to pull out if it's good?
Thanks for the help!
Old 01-21-2003, 01:20 PM
cbx-man cbx-man is offline
It's a great idea depending on several factors. 1) Cost of the core. 2) Your long-term commitment to the SVX. 3) Disposable cash for the core and a QUALITY rebuild. 4) Reduced down time for swap.
approx $2000 for DRW Transmission to rebuild
approx $4000 for Level 10 to rebuild
cbx-man
'92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter
'92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft
'80 Honda CBX in-line 24 valve 6 cylinder
Old 01-22-2003, 08:26 AM
Noir's Avatar
re: expensive
damn that transmission is expensive
Old 01-22-2003, 08:39 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: re: expensive
A reputable rebuilder can rebuild it for around 1,200-1,500 dollars. Just make sure they also replace seals/bearings in front diff.
Randy Johnson
Mike Davis -- at Reading VI
Old 01-22-2003, 03:36 PM
If you can get it cheap, just set it back, it was working good enough to wreck the car it was in so it should work good enough to use in your SVX untill you can have yours rebuilt.
That way you don't have to put up the extra $$ unless yours goes south
Old 01-22-2003, 09:08 PM
Noir's Avatar
re: huck
that's what i was thinking huck. if it works for a bit, might as well get it if it's cheap. good to have a spare since the transmission subaru made is such a problem to some. but whoever needs a front end, the front end on that wrecked svx is immaculate. the hood, front, lights all are in VERY good condition. hood looks brand spanking new. the salvage yard plans to cut off the front and sell it for $1000. the passenger side was in a t-bone wreck. trunk is without a spoiler but also in very good condition. actually it seems MUCH MUCH lighter than my trunk for some reason.
Old 01-22-2003, 09:31 PM
Aredubjay's Avatar
Re: re: huck
What color? I'm needing a Pearl hood, front bumper and RF fender.
Randy Johnson
Old 01-23-2003, 10:42 AM
if you dont mind
i need the lifting assemblies for the hood and trunk on my car and if it has leather seats that were gray i could use that too especially the rear seat the folds down..when i put in my stereo i was sittin on the seat with it folded down and it was so old and dry it cracked when it was pushed down into the center console anyhow thanks for any help
Old 01-23-2003, 01:16 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Axles
If you get the tranny you might as well get the axles too. Once they're off you shouldn't have much trouble rebuilding them yourself!
Old 01-23-2003, 03:55 PM
Noir's Avatar
re: that svx
the color is the cal...whatever...the burgandy kinda red. once again the front is immaculate. i know they want $1k for it. two marker lights are basically brand new. i don't know how much you want to spend, but it's really nice. the rear latch and those mechanisms for the trunk are in great working order. the seats suck, leather and cloth and full of broken glass.
if you want to redo some seats, a friend of mine's uncle does reupholstery so i can find out how much to redo them. i'm thinking about redoing my seats.
