Old 12-18-2002, 07:24 PM
Alcyone SVX LSL
Question Tranny noises....
When i come to a stop in my SVX and i have the SVX in any forward gear it kinda ticks, you can even feel it. If i put it into "N" it will stop and if i pull it back into "D" it doesnt make the sound until i have moved some then reaply the brakes then the sound and vibration kinda feeling comes back..
Any ideas?
Old 12-18-2002, 08:28 PM
lee lee is offline
I really have no idea, but was thinking that maybe the rear mount is at fault. If it's in neutral, there's no side load??? and maybe there is in drive??? so it could be shaking on the mount.
again, no real idea, just something to check if somebody with experience doesn't jump in.
Old 12-18-2002, 09:18 PM
Uncamitzi's Avatar
Member #447
Re: Tranny noises....
Any ideas?
This is what I described here about a week ago... Beav said to check my vacuum hoses under the intake manifold... I haven't done it yet and I still have this same vibration that you are talking about.....
*edit (of course I have the vibration.... I haven't checked anything yet!!! doh!)
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 12-19-2002, 03:23 PM
Tick,Tick,Tick.
This could be a crack in the flex plate that mounts the torque converter to the crankshaft?
Old 12-19-2002, 03:56 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
A broken tranny mount usually manifests itself with a loud "thunk" when pulling out, in reverse, from a standing stop.
Randy Johnson
Mike Davis -- at Reading VI
Old 12-19-2002, 04:19 PM
lee lee is offline
thank you - typed while mentally trying to find a place to file this info for future reference.
Old 12-19-2002, 07:38 PM
Invisible avatar
Thumbs up
I have yet another brilliant idea for those of us who try to verbally describe automotive zoo noises. "Thunk, clank, tinkle, thud, whump, rata-tata, screech, etc., etc." could be represented by icons like smilies. We could then quickly relay those strange sounds to the group by a few keystrokes. Something between a Thunk & a Clank could be #/*, & we'd instantly know what part needed replacement!
Any suggestions for icons? I can't make smilies work from this computer.
Ron (better living through hair-brained ideas).
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 12-20-2002, 09:44 AM
Alcyone SVX LSL
OK the mount could be the problem, if it is common to make noises while on the brakes at a stop. The when going in reverse i have heard #(thunk) but i always figured it was crap in my trunk cause my trunk if full of everything from parts, tools, to subs and bottles of ATF and oil.
Is there an easy way to figure out what is the problem, or would it need to be jacked up and have a close look at them all.
Old 12-20-2002, 09:51 AM
lee lee is offline
I don't know about easy, but take all the stuff out of the trunk and see if the noise is still there - wouldn't require jacking (but might require leasing storage space depending ).
Old 12-20-2002, 10:23 AM
Aredubjay's Avatar
Lee, that was going to be my "technical" suggestion also.
The "thunk" is the tranny flexing and bumping the underside of the car. It's quite distinct.
Randy Johnson
