Old 12-18-2002, 07:02 PM
LarryIII LarryIII is offline
Perplexed
I have an interesting problem. I drove my 97 SVX LSi to work this morning with no peoblems. I parked in the open air garage on the ground floor of the building where I work. The car has 49,000 miles on it.
Tonight when I left work I started up the car and let it warm up.
The 'Check Engine' light stayed on. I shut it off and restarted the car. The light stayed on again. I popped the hood and checked the oil. I 'd say it was about 1 quart low. I restarted the engine and let it come up to normal temperature. The engine idled as always and was very quiet as usual. When the engine was fully warmed up I shut it off and checked the oil level again. It was the same as before. The engine idled smooth as silk. I decided to go home. I drove slow in traffic and reached home. The 'Check Engine 'light stayed on the whole way. I put the car in our garage and put about 1 1/2 quarts of Mobil 1 in it. It is slightly over-full now. The light stayed on. I'm perplexed. There doesn't seem to be anything wrong with the engine. Could it be the sensor? Does anyone have any ideas and/or suggestions?
PS: There are no indications of any leaks and the exhaust is clean.
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 12-18-2002, 07:20 PM
Alcyone SVX LSL
Did you check to see if it had any codes showing up?
I had a weird one today, i was just driving along and my check engine light blinked as i was driving but went back out in about 2 seconds b4 i could pull over to do a look over
Old 12-18-2002, 07:27 PM
Leslie,
Thanks for reponding. In a '97, there is no way to check the codes yourself without the code reader. It has OBD II. I have to get it to a dealership.
Old 12-18-2002, 07:41 PM
Invisible avatar
Larry old buddy. I thought most "check engine" lights on just about any vehicle had mostly to do with policing the emissions system. Granted, that could indicate a naughty sensor somewhere, but I really doubt that it cares if you're 4 quarts low. I defer to Beav now.
Ron (playin' mechanic).
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 12-18-2002, 08:49 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Yesterday I couldn't spell mechanic, today I are one.
Low fluids have no impact on the MIL (malfuncrion indicator lamp.) Transmission fluid temp does.
Some codes are serious, others are fairly benign. Check to see if you put your gas cap on firmly, that's a common slip-up that will set a code. If it's loose it may take a day or two to turn back off. If it's tight you really should have a peek at the codes.
Old 12-18-2002, 10:51 PM
vzSvx's Avatar
vzSvx vzSvx is offline
Send a message via Yahoo to vzSvx
Originally posted by LarryIII
Leslie,
Larry, do you see any Auto Zone in your area? They will check it and clear it for you for FREE. I went to them one time but they can't do it to mine because I have a 92. They can't go that far down.
- Viv
1992 SVX LS, Claret "Caressa"
"Striving for excellence motivates you. Striving for perfection is demoralizing.".
Old 12-19-2002, 04:43 AM
MT,
My dealer does it for me for free. I have a good relationship with him (I bought 4 Subys from him). Tonight I'll tighten the gas cap but it's probably a polution sensor.
Old 12-19-2002, 07:39 AM
Alcyone SVX LSL
MT,
That was Viv..
Old 12-19-2002, 12:50 PM
Sorry Viv & Leslie,
Today is our Christmas Breakfast/Party here at work.
I guess I'm getting too old now to start drinking scotch before 7:00 in the morning.
Now I know how Ron feels.
Old 12-19-2002, 01:01 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
The C/E light usually indicates O2 sensor(s), but, have the codes checked, especially if it's free. I've been having an intermittent C/E light myself. I need to pull the code. I did, however just replace the o-ring on my dipstick. I was having the "mysterious levititating dipstick problem." The o-ring had become flat and brittle. Hopefully, it's not a PCV valve problem. That's such a b***h to get to.
Randy Johnson
Mike Davis -- at Reading VI
Old 12-19-2002, 01:10 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Sorry Viv & Leslie,
You mean you get to a point where you are too old to handle Scotch at 7:00 AM???
To quote El Presedente: "AAARRRGGGGHHHH!!!!!!!"
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 12-19-2002, 04:33 PM
Beav's Avatar
Not as old as Randy
Bring it on over, I'll have the PCV in and out in less than ten minutes.
Old 12-19-2002, 07:20 PM
Invisible avatar
Talking
No fair doin' it when you're sober!
Ron (checking boozometer)
'01 Miata SE - 79K
Old 12-19-2002, 09:53 PM
Aredubjay's Avatar
Randy Johnson
Old 12-21-2002, 06:54 PM
greg
I imagine that there is a direct relationship to the type of gas that is used in the car and the C/E light? I have on two occasions used less that adequate gas for the SVX. Both times were 93 octane but from a station that is less than reputable and both times My light came on for a brief moment. I have never used that fuel again from either of the stations andf I have not had the light return??
-G
