Old 09-20-2010, 01:06 PM
Re: dash light bulb replacement numbers
Yes, both were LS-L's with heated mirrors.
Old 09-20-2010, 01:17 PM
Whe you pull out the switch clusters from the dash, the illumination bulbs are inside the BROWN sockets. They are the ones closest to the face of the switch panel. Just unscrew 1/4 turn to remove, using a small screwdriver.
Thw BLUE sockets towards the rear house the indicator lights. I have never had to replace those.
Old 09-20-2010, 01:35 PM
NeedForSpeed NeedForSpeed is offline
Thanks for the last post on bulb location, very helpful
Mystery about the 92 Parking switch, In time, I'll report on the switches in our other 92s..
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 09-20-2010, 03:43 PM
Almost as much of a mystery as the leather steering wheels on the 92's. Some had four seams while some only had two...
That thread is HERE
Old 09-20-2010, 04:31 PM
That thread is HERE
Okay, you got me again, I missed that one ,
now something else to check out when/if the 92s find the way home.
My JDM with radio controls is a two seam, just as Joe reported his, but I doubt I would have figured it out without reading your last post .
Perhaps the US two-seamers don't have an amber bulb in the parking switch, it's an early 92 thing?
Old 09-24-2010, 05:04 PM
With the help of this thread I changed my foglight, security, rear defrost and hazard illumination dash lights. The bulbs were $1.88 for a 2 pack at Radio Shack. There is something deeply satisfying about fixing those little buggers.
Plus I got 2 compliments on my STI wheels. It was a good SVX day.
Old 09-24-2010, 06:26 PM
what was the Shack part number for the illumination bulbs?
Old 09-24-2010, 06:51 PM
#7219 Micro Lamp
12 Volts 60ma Wire terminal base
item number 272-1092
http://www.radioshack.com/product/in...ductId=2103780
You will reuse the brown base, wrap the wire terminals around the base the same way it was before you removed the bulb. Clip off the excess, slide the green plastic sleeve over the bulb and put it back in the switch.
Old 09-26-2010, 05:58 PM
So noticed that I need to change the illumination light on the power mirror arrows. I pulled it off the dash, but I can't see where the bulb goes. Does the switch need to be disassembled further to get at the bulb?
Old 09-26-2010, 08:38 PM
Manarius's Avatar
Manarius Manarius is offline
::EDIT:: If I recall, it has lots of little springs and stuff in it though.
-Jason
-Obi Wan Kenobi
Old 09-26-2010, 08:52 PM
My 92 LS-L Pearl has lighted arrows, and an amber Parking switch bulb .
my 92 JDM VL Pearl doesn't have either, for whatever reason .
Thanks to SVXCESS, I've been checking it out, thanks John
Old 10-14-2010, 12:29 PM
SoobCrazy SoobCrazy is offline
SVX n00b
For those who have replaced the bulbs in your CC/defrost/security buttons, how the heck did you get the buttons out of the dash. The passenger's side bank came off no problem, but it feels like I'm going to snap the Driver's side bank in half when I try to pull them out.
Any suggestions on how to nurse the buttons out of the dash without resorting to the "Hulk Smash" method?
Old 10-14-2010, 05:13 PM
For the one on the drivers side:
Carefully pry up on the left side with the tip of a flat screw driver till it starts coming out. Once you get it a little ways out, it will leave a slight gap, re-adjust the blade of the screw driver so that goes in a little further and can pry with a little more force. Then with your other hand, pull up on the right side while continuing to use the screwdriver to pry up the left side.
At least that is what worked for me.
