Old 07-28-2016, 10:19 AM
kuritsa kuritsa is offline
Time to say goodbye
Well my Svx failed its mot today. The reason was a worn hub. When taken apart the abs ring broke up and was shown the wear on the hub. Unless I can find a reasonably priced hub and ring then it will have to broken. Sad I know as drove it home and purred like it always does. Very upset.
Old 07-30-2016, 03:34 AM
scoobymal's Avatar
scoobymal scoobymal is offline
Re: Time to say goodbye
That's not a major job, try these people http://windley.dhsystems.co.uk/break...rol/automatic/ they been very good for me in the past.
Mal
Old 08-15-2016, 02:05 AM
Unhappy Re: Time to say goodbye
Thanks for the tip Mal. I tried them but couldn't help. Still searching. I have found a supplier in the states but they want a lot of money for the parts and not sure if I can justify the expense. Will keep trying. Something may turn up. Don't really want to let it go with only that stopping it getting an mot. Frustrating.
Old 08-18-2016, 07:15 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Try this crowd - here in New Zealand, send them a picture of what you require...
http://www.trademe.co.nz/motors/car-...1143489530.htm
Let me know if they are willing to send to you - if not I can arrange for pickup & postage to you.
regards
Steve
