Old 12-08-2015, 05:54 PM
longassname's Avatar
Just some dude.
SOLD New STD size Aluminum Rod bearings
I have a complete set of 6 made in Japan Clevite Aluminum rod bearings for an EG33 sitting around not being used I'd like to clear off my shelf.
Standard size
These are the made in Japan Aluminum bearings that cost about twice what tri-metal bearings do. These are the bearings all the auto manufacturers have switched to in recent years because they essentially last forever. They are also a much safer bet than tri-metal bearings because they have a much thicker friction/wear surface so they are much less prone to catastrophic failure.
$70
(Revised: sold)
Old 12-08-2015, 07:42 PM
fasteract7's Avatar
fasteract7 fasteract7 is offline
Re: New STD size Aluminum Rod bearings
Michael, is there a less labor intensive method I could swap these bearings in...like dropping the oil pan only giving me access to the rod bolts?
THX
Old 12-08-2015, 10:10 PM
Just some dude.
unfortunately no
Old 12-09-2015, 01:21 PM
Just some dude.
I've listed on them on ebay as well. Better if you buy here ...
http://www.ebay.com/itm/231779050252...witem=&vxp=mtr
Old 12-16-2015, 08:42 AM
Just some dude.
relisted: http://www.ebay.com/itm/231785554362
Old 12-19-2015, 06:59 AM
Just some dude.
Whoever was asking me about these from here on ebay it would be better if you asked me about them here. My email is usfwalden@aol.com
Old 12-20-2015, 07:43 AM
Just some dude.
I didn't hear from the person from here who messaged me on ebay so I relisted them. I'd rather not pay the ebay fees but oh well. I turned it into an auction starting at 99 cents with a buy it now for $70. I believe the way it works, the buy it now option disappears with the first bid.
http://www.ebay.com/itm/231789598768
Old 12-20-2015, 11:57 AM
bishop bishop is offline
I wish I knew whether I needed these or the oversize at this point, I wont be tearing down the engine till spring though.
Old 12-20-2015, 07:21 PM
Just some dude.
if your engine doesn't have a rod knock you need standard size bearings.
if your engine has a rod knock you will need oversize bearings.
Old 12-21-2015, 12:50 AM
Well then its a done deal! PM me your details and I'll get you payed.
Old 12-21-2015, 09:26 PM
Just some dude.
Payment received. Bearings are sold.
