Old 06-30-2015, 02:30 PM
Andrew P.'s Avatar
Andrew P. Andrew P. is offline
The Ebony ones are faster.
AMR coilovers finally installed.
Just picked-up my car this morning.
Drove it for a while to check it out. Then made an appointment for an alignment check.
I have them set at 2 clicks up from full soft to help with letting them settle.
Saw little to no nose dive under hard braking. I like it.
Found out that I do have to replace the front sway bar end links
though. Found them on Rock Auto so no biggie.
92' Ebony. Magnaflow exhaust, tinted windows, STI wheels, 97' grille, Bontrager Works SB, ECUtune transaxle and TCU.
77' IHC Scout SSII
Old 06-30-2015, 03:25 PM
gwynethh's Avatar
gwynethh gwynethh is offline
Re: AMR coilovers finally installed.
"Found them on Rock Auto so no biggie."
Part number and cost??
"Peace is the flower of justice."
Old 07-01-2015, 07:58 AM
Andrew P.'s Avatar
Moog part# K750634, $18.81 ea.
77' IHC Scout SSII
Old 07-04-2015, 09:14 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
If I remember correctly, the AMR pieces don't allow the rear dampers to be adjusted without removing them from the car ?
Are they also only single adjustable?
Thanks
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-05-2015, 04:51 PM
Andrew P.'s Avatar
Well, the damping is adjustable by the top adjuster knobs.
But from what I can see, the top mount rubber bushings are pretty tight. The only way I can see to adjust height on the car would be to back off the spring pre-load, loosen the top nut and then turn the cartridge body in or out. Then tighten everything back up and check it.
Kind of a hastle but oh well.
The fronts are way easier since they have a top bearing instead of a bushing.
Hope that helps.
77' IHC Scout SSII
Old 07-05-2015, 07:47 PM
SVXRide's Avatar
So, the rear dampers have a knob to adjust the amount of damping provided? The problem we've always had with the Koni inserts in the rear is that you had to remove the entire strut to adjust the amount of damping.
Thanks
Bill
Old 07-07-2015, 09:05 AM
Andrew P.'s Avatar
Front and Rear.
Check out AMR's website for more info.
www.amrengineering.com
77' IHC Scout SSII
Old 09-02-2015, 11:18 AM
PhyrraM PhyrraM is offline
Can you give any driving impressions for various conditions now that they have been installed a month? Also, a quick rundown how you configured your set?
I'm ready to buy my set and just looking for confirmation that the US assembled, superbly machined AMR is the correct choice.....
Old 09-20-2015, 06:24 PM
Andrew P.'s Avatar
So far I like the ride quality. A little stiffer but not harsh. I have the damping set at 2 clicks up from full "soft". I figured that would help it to settle.
I'm going to take it back in for height adjustment and alignment re-check pretty soon.
Other than that, I'm very happy with them.
77' IHC Scout SSII
