Old 06-20-2015, 07:30 PM
kysvx kysvx is offline
Time for a water pump?
My car was overheating this week after driving at highway speeds then slowing down into town. I looked for leaks last night and found the only place where coolant is showing is towards the front of the oil pan, which from searching the forum indicates a possible water pump leak. I ran the engine to temp with the radiator cap off to make sure coolant was flowing and found just a small amount of coolant showing so i filled the radiator and let it run. Then filled the reservoir and it runs fine today. However, I'm sure it will happen again due to the invisible leak so a water pump replacement will probably be in order soon. Looking through the threads I believe I have gathered all of the parts I will/may need for the job as well as those that will be beneficial to tackle while I'm in there, but I would like an expert on the subject to sign off before I put in the horrendous order. If there are any of these I will not likely need also please let me know because my funds are limited at the moment.
Timing Belt 13028AA120
Idler pulley 1 13085AA020 (x2)
Idler pulley 2 13073AA150 (x2)
Tensioner 13069AA070
Tensioner adjuster 13068AA051
Intake cam plugs 807045030 X2
Exhaust cam seals 806732150 X2
Bolt 800112080 X4
Camshaft bolts 800112080 X2
Bolts 10508220 X6
Oil Pump O-ring 806919050
Oil pump seal 806733030
Thermo cover/inlet 11060AA061
Thermostat 21200AA072
Thermos cover bolts 10406250 X2
Thermo gasket 21236AA010
Water pump 21111AA033
Water pump gasket 21114AA051
Water pump sealing 21116AA020
Hose WP to bypass 807611101
Hose WP to return 807615131
Hose bypass to engine 807611111
Bolts 800106930 X6
Hose clamp WP to bypass 805918010 X4
Hose clamp WP to return 805922090 X2
I will replace all of the coolant which I have not done before so I don't know if there are any replacement parts I will need for that process besides fluid.
Also, I do not have another vehicle I can drive at this time and have a good bit of driving I will need to do in the next couple of weeks. As long as I keep an eye on coolant levels and add as needed do I need to be worried?
I appreciate any insight any of you can give!
Thanks,
Patrick
'94 Barcelona Red LSi - Daily driver, future project
Old 06-22-2015, 11:21 AM
Re: Time for a water pump?
How many miles are on your SVX?
the water pump should be replaced when you replace the timing belt, but many don't.
There are timing belt / water pump kits on ebay that have all the components you need, for a lot less than OEM, if you're not set on OEM
Old 06-22-2015, 08:00 PM
196k+ miles. I would be fine with using a kit if people have had good experience with them.
Old 06-23-2015, 05:52 AM
I've used the ebay kits with good results...that's what is on my Yellow 5-Speed for 5 years now
Old 06-23-2015, 07:19 AM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
I believe Nate and some others recommend going with an OEM water pump. The ebay timing belt kits themselves are fine otherwise.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 06-24-2015, 08:29 AM
Ok thanks for the suggestions
