AA794 TCU testing?
Is there a way to test a tcu out of the car before installing it? I had a code 24 and the binding when putting it into park from drive. It would also rock backwards when the engine was shutdown, but all of it would go a way when I put the fwd fuse into the slot. So I figured it wasn't the solenoid. No more rocking, no more binding, no more power light flashing, no more skidding forward on tight turns, etc... So I was going to try swapping out the tcu. So I was wondering, since any tcu I get is going to be used is there a way to test it outside of the car to insure it is good?
Any other ideas to try before I replace the tcu? Thanks, Tom
1992 Silver SVX LSL 180,000mi 2010 WRB WRX wagon |
Re: AA794 TCU testing?
For the longest time I never saw TCUs go bad. Then starting a few years ago I started hearing more and more reports of bad TCUs. I've seen a few myself now. In every one I've seen the failure was caused by a leaking aluminum capacitor. When they leak the fluid corrodes the traces on the circuit board and destroys the TCU.
Aluminum capacitors just don't last forever and when they leak they destroy the electronic device they are in. It's a common scenario in electronics. I'm not saying your TCU is bad but since you suspect it is bad I would open it and look at it to see if any of the capacitors have leaked. It's become a common enough problem that I recently put in the research to identify what the OE capacitors are and procure a stock of them. I'm going to start pro-actively replacing them in every TCU I socket for a performance chip. |
Thanks, I'll have to open mine and take a peek.
I have an ecutune ecu in mine but paid the core to keep mine so I had a backup. It was working fine when I took it out but wanted to protect my newly rebuilt transmission. I could send you mine for testing purposes if you need it.
Current Stable: 1992 SVX 1979 K5 Blazer Cheyenne 1956 Plymouth Belvedere - Daisy 1967 Chevy C20 1953 Chevy 210 1969 Plymouth Satellite 1949 Chevy Thriftmaster 1959 Chevy Apache 1951 Chevy Stepside 1969 Chevy Camper Special 1978 Ford F150 w/ stroked 460 1986 Volvo 740 turbo wagon 1999 GMC 2500 Creep Van 1994 Impreza Outback |
Thanks, Tom
i dont think it makes a difference but will find mine and see what it says on it.
I'll be out of town next week, but I'll pm you when I get back and see about using your tcu to troubleshoot the tranny.
Thanks again, Tom
Thread Tools | |
Display Modes | |
