Old 02-22-2015, 09:34 AM
simboglide's Avatar
simboglide simboglide is offline
Water Pump
Seems it's time to change it, and I'm guessing it's the original. 180k, noticed drip spot on driveway, dripping off xmember, pulled up on ramps, dried everything off and ran it back to the water pump mounting area. It seems Subaru didn't use a gasket out of the factory?Already changed the oilpump seal and O/R, new idler pulleys a year or so ago along with P/S oring and cam seals. timing belt and hoses are coming with waterpump.. new t-stat (factory one is a BEAST) Missing anything?
Old 02-22-2015, 12:12 PM
Re: Water Pump
Carefully cut off the "jiggle pin" to allow a little more water flow, but beware when you cut it it goes off like a rocket!
Old 02-22-2015, 01:58 PM
simboglide's Avatar
Re: Water Pump
Really?? snip it?? I though it was only to allow air bubbles to pass.
Old 02-22-2015, 03:52 PM
Re: Water Pump
Afterward you will be able to fill your cooling system faster,
your engine will run just a little cooler,
it will take about another minute before the engine gets up to temperature. So no downside.
If you find this hard to believe wait till I tell you about porting your thermostat cover!
Old 02-22-2015, 05:27 PM
simboglide's Avatar
Re: Water Pump
Now there's a thought, it is just aluminum. debating weather to take the intake off, there's a bit of oil under there.. assuming from IRIS valve.
Old 02-22-2015, 05:43 PM
Tireiron Tireiron is offline
Re: Water Pump
Subaru uses a gasket for the water pump, and ONLY use a subaru gasket. It is a metal coated gasket and all that is needed with the machined surfaces of the engine block and water pump.
Old 02-22-2015, 05:54 PM
simboglide's Avatar
Re: Water Pump
Don't use anaerobic sealant to lightly coat it?
Old 02-22-2015, 06:21 PM
Re: Water Pump
Nope. Subaru O-Ring gasket.
Old 02-22-2015, 07:43 PM
simboglide's Avatar
Re: Water Pump
Sorry, i should have "quoted" Tireiron....I know there's a rubber seal on the t-stat and what looks to be a coated metal gasket on replacement w/ps
Old 02-22-2015, 10:17 PM
Re: Water Pump
And no, you don't use anything on the water pump gasket. Just nice clean machined surfaces. The nice thing with the OEM gaskets, is when you take the part off, the gasket pulls right off leaving a nice clean surface.
Old 02-24-2015, 09:41 AM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
Re: Water Pump
Does this help with the dreaded high-rpm cavitation issues?
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 02-24-2015, 02:32 PM
Re: Water Pump
I have not gone to the lenghts some have by actual scientific testing, clear hoses etc.
But the inside of the thermostat has some pretty sharp edges.
Once ported and smoothed they SHOULD provide a smoother flow.
Old 02-28-2015, 11:21 PM
simboglide's Avatar
Re: Water Pump
i think I may have bent my cam pulley installing it... it rubs the plastic back cover in a timed mode( click click click) and i have a vibration....grrrr
Old 02-28-2015, 11:31 PM
Re: Water Pump
Or the plastic has shifted/seperated/movet to the point of causing contact.
With the outer cover removed you can chect to see if the pulley is true.
Old 02-28-2015, 11:59 PM
simboglide's Avatar
Re: Water Pump
sighss...i started it..i can see the timing belt slightly walking back and forth.
