Old 02-04-2015, 01:18 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
AWD ratio?
Got a flat on the front driver side. They are snow tires. Can I put my all season tire on? Will it effect the driving? Maybe use it on the rear instead? What is the all wheel drive ratio, 50/50 or 60/40? Maybe this will determine where to install the all season tire?
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 02-04-2015, 01:29 PM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
Re: AWD ratio?
Yes it will affect it. Just swap on all 4 of your all-seasons.
I can get around just fine with my all-seasons in deep snow.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 02-04-2015, 02:39 PM
Re: AWD ratio?
The ratio changes according to wheelspin. In normal driving it's 90/10.
It's likely a different circumference than the snow tires, so it should be put on the rear and install the FWD fuse under the hood. Get the flat fixed ASAP and get back to AWD.
Old 02-06-2015, 05:28 AM
Re: AWD ratio?
Being the rear on the SVX is a Limited Slip, one odd tire is a bad ideal on the front or back, put 2 matching on the front or back, and install the FWD fuse until you have 4 matching on it....
Old 02-10-2015, 12:52 PM
dannmarr's Avatar
I work for my SVX
Re: AWD ratio?
Thanks for the replies
Subaru SVX for fun
