Head Light Replacement
Hi I got this description for the HL replacement from one of the "how to doc's": R/L High Beam Lights 9005
Is this the OEM lights or improved after market part. I have a 92 SVX with extremely weak lights. I can hardly see a thing driving in the dark and I have fairly good eyesight. |
Re: Head Light Replacement
Check the clarity of the lens and use some lens repair if cloudy or yellowing. If you want to stay close to OEM get something like Sylvania SilverStars https://www.sylvania.com/en-us/produ...tar-ultra.aspx of the appropriate size IE 9005. HIDs are available but are a bit of a wiring chore.
"Peace is the flower of justice." |
You can also use high beam bulbs in the low beam sockets with a minor modification of the bulb base.
There's a "How To" doc. The low beam is a projector type and will not blind oncoming drivers. Personally I wouldn't bother with the Silverstars. In my experience they give a minor improvement in brightness, are expensive and burn out very quickly. |
First check what type of bulbs you have fitted, UK, JDM and Europe have H1 and H3 fitments. I fitted HID to mine, was easy, no wires to cut or join.
DDM Tuning has Plug and Play HID kits for 9006 (low beam). It only takes about 5 minutes to change the stock bulbs for HID's. Definitely clean up your headlights if they are yellowing, it makes a big difference.
Sam Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners My Locker Last edited by Svx95; 01-30-2015 at 11:36 AM. Reason: bulb type |
I agree. Polish the headlights add some sort of protection and put in a DDM tuning HID kit.
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
Thanks for all the help guys! Will definitely have to do a cleaning job first!
@Scoobymal, how will I know what type of bulbs I have fitted? Service manual, I suppose? @Sean486, are these DDM tuning kits available to order online? |
HIDs at http://www.ddmtuning.com/Product-Cat...and-Components
Thread Tools | |
Display Modes | |
