Old 11-16-2014, 09:29 AM
Torque specs for rear subframe bolts
So the service manual calls for 94-116 ft-lbs on the "Crossmember to body bolts". I assume those are the four large ones that go through the subframe. Does anyone know what the specs are for the shorter bolts that go through the secondary parts? (two brackets in front of the subframe, two behind as well as the swaybar mounting brackets). There is a spec for the "crossmember support bolts", but it's only 33-54, which seems a little low to me.
