Old 11-02-2014, 08:03 AM
Huskymaniac's Avatar
Uses the ignore feature
Damn wheel bearings!!!!
Since I bought the car with about 74K miles on it in late 2010 I have replaced the left rear bearing twice and the right once. The right sounds like it is starting to go again. When I did the left for the second time, Nate had suggested replacing the hub too so I did that. I also replaced the grease with Redline grease but I am not sure that was necessary as Timken claims they pack them now with the proper grease. I also don't know if I did a particularly good job. So I guess I will replace the hub with the right bearing this second time around on the right side. Maybe sitting for a year contributed to this or maybe it is because I didn't replace the hub the first time but it is damned frustrating. Hopefully I am done with this crap.
Anyone know how I can get a bearing and hub quickly? Do most dealers carry them or am I going to be forced to wait until they come from a warehouse somewhere?
Tony
Old 11-02-2014, 01:55 PM
Re: Damn wheel bearings!!!!
Did you torque the nut and press the bearing properly? Do you have aftermarket axles? There has to be a reason for the failures. Maybe you have the wrong offset on your wheels.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 11-02-2014, 03:05 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
There's gotta be a way to get STi hubs to work. We use the same bearings and lateral links and struts for the most part...
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 11-03-2014, 06:04 AM
The trailing arms don't match, you'd need a custom one to put STi rear knuckles in an SVX. Our trailing arms are straight and come off the knuckle at an angle. The STi ones come directly forward from the knuckle and have a kink to clear the wheel. Basically the angle built into the STi knuckle won't align with the attachment point in our subframe.
Now, that being said, a trailing arm isn't a huge challenge for someone with half-decent fab skills. The non-parallel pivot points would put stress on the bushings unless a heim joint was used for the forward end to free up some motion.
Old 11-03-2014, 06:33 AM
Tireiron Tireiron is offline
The strut mounting point on a rear STi knuckle is in a different place than on the SVX also. On the SVX it is vertically above the wheelbearing, on the STi it is off to the side. This puts the STi knuckle at a really bad angle if you tried to mount it up.
However I think he is asking of the STi wheel hub and wheel bearing work on the SVX. This is something I've been curious about also seeing as we use the same 190mm parking brake assembly and can direct bolt the STi rear CV shafts in. It would be interesting to cross reference the rear hub and bearing part numbers between the two.
Old 11-03-2014, 06:36 AM
what about Tribeca?
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 11-03-2014, 07:15 AM
Ah right. For some reason I was thinking that the STi bearings were the bolt-in variety, but that's the fronts only. It wouldn't be too hard to figure out, just need some measurements to confirm. Does anyone have a bearing out that they could take a few dimensions off of?
Old 11-03-2014, 08:03 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
I am changing the rear wheel bearings on my newly purchased '94. The previous owner had them changed by the Subaru dealer less than 4,000 mile ago. However, not the hubs. I would hope they knew how to pack the grease and torque the nut. The passengers side is louder than the drivers side.
I purchased the hubs from Subaru.com and had them within a week.
Gene and Ben
Old 11-03-2014, 08:09 AM
How much did the hubs cost?
Old 11-03-2014, 10:20 AM
2004 to 2007 impreza uses the same bearing.
Wheel Bearing I.D. : 1.654"
Wheel Bearing O.D. : 2.834"
Wheel Bearing Width : 2.054"
Current Stable:
1992 SVX
1967 Chevy C20
1953 Chevy 210
1959 Chevy Apache
1951 Chevy Stepside
Old 11-03-2014, 03:21 PM
bwb3's Avatar
$143.96 each, plus shipping.
Gene
Gene and Ben
Old 11-04-2014, 06:18 PM
Scoobyru's Avatar
Scoobyru Scoobyru is offline
Gene
I was told by one of my Subaru Instructors, who is a Senior Master Tech who has done tons of SVX bearings, that sometimes even the Knuckle is warped from air tightening the long bolt throw the parallel links too tightly... so when i replace my wheel bearing in the spring it will be with all included... sucks but better to be safe than sorry...
1992 Dark Teal LS-L 237k #103994 (Sold)
GC8 Nardi Steering Wheel/
Crossed Drilled Rotors/
18" Exel Evo Wheels/15min Mod/
6k HIDs/ECU Crush Mod/
Power Mode Mod
1997 Brilliant Red LSI 151k #100109
PWR AU Radiator, Stebro Catback, Hella Supertones, SS Brake Lines, Cross Drilled Rotors, QC, Power Mode Mod, SSR GT3 Wheels 18x8 et35
1997 Ebony Mica LSi 177k #100321
Old 11-09-2014, 05:14 PM
Is this a rear hub and does anyone know anything of the quality?
http://www.amazon.com/OES-Genuine-Wh...3Asubaru%3Asvx
Tony
Old 11-09-2014, 06:10 PM
That should be an actual Subaru part. I bought an OES ball joint from Autopartsway and it came in genuine Subaru packaging with a Subaru part#.
Original Equipment Supplier.
Old 11-09-2014, 06:19 PM
or OES……
Old English Sheepdog
here is a head shot, she weighs 109 pounds…and that is a bar height chair at her head level.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
