Old 08-30-2014, 12:05 AM
Alex-svx's Avatar
Alex-svx Alex-svx is offline
Help my car stops??
I have a problem whit the car. A month ago the knock sensor and the O2 sensor came up on the engie fault codes. and i have replace the knock sensors and build a new exhaust system and replace the O2 sensor. (all OEM parts). Its a exhaust shop that have build the systems.
Before i replace the exhaust, i drive the car to the shop. And in crusing speed the engie cuts (like its not getting anny fuel) like 2-5sec some times. And the check engine light came on and i read the ecu. And then the O2 sensor came on. (the knock sensor hase been repalced the day before). But i also got a new code the water temp sensor. And after the shop was done whit the car.
I pick it up on a trailer and drive it home. When i should drive the car on the trailer the engine stops. And the same thing happen this morning. I drive out of the driveway and the engine stops. I have try to read the ECU and only the water temp sensor is show there.
So what is the next to look at?
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
Old 08-30-2014, 03:06 AM
Tapani Tapani is offline
Re: Help my car stops??
Re-solder MAF
/T
Old 08-30-2014, 09:12 AM
Alex-svx's Avatar
Tested the car and i got a new code airflow meter? That is the maf?
Alexander (Norway)
My subarus:
Old 08-30-2014, 09:55 AM
gwynethh's Avatar
gwynethh gwynethh is offline
MAF=Mass Air Flow so airflow meter is it.
Old 08-30-2014, 09:56 AM
MAF (mass air flow ) it does something similar to what the old choke did on a carb engine. Measures the Air Flow. It send a signal to the computer to regulate gas flow/ air mix. I know I will get flamed for this answer.
Inside there is a wire like a toaster filament. It is heated. Depending on how cold or how fast the air flows through determines the heat of the wire and this is how the computer knows what to do. If the wire is loose or broken it will cause the car to shut off. With the motor running tap on the air cleaner with the back of a screwdriver.
Old 08-30-2014, 02:23 PM
Alex-svx's Avatar
Thanks alot for the help i will order a maf and watertemp sensor. Hopefull i will drive the car a little before the winter.
Alexander (Norway)
My subarus:
Old 08-30-2014, 09:23 PM
i will order a maf
It's very easy to repair the one you have. At least worth a try - they are not cheap. Search for re-solder maf, there's a "how to" pdf.
/Tapani
Old 08-31-2014, 03:40 AM
Alex-svx's Avatar
I will take a look on it. Thanks.
But some one know the part number for the water temp sender for the ecu?
Or is it this one:
Powertrain control, Coolant temp sensor
SVX
ELECTRICAL »Powertrain control
Subaru › Svx › 1992-1994
List Price : $26.95
Your Price : $19.73
The link on subarugenuineparts will not be copy.
Alexander (Norway)
My subarus:
Old 08-31-2014, 06:18 AM
Brought mine in the shop for the same problem. The machanic ordered the rebuilt MAF before consulting me. He would not repair the old one and would not wait til I found a used one $ 450 later my car runs better than it ever did.
Old 09-21-2014, 05:20 AM
Alex-svx's Avatar
I got my new maf from subaru yesterday. And now the car runs good again. And the water temp sensors is also gone form the ecu. I have order a new one so this will also get replaced.
Alexander (Norway)
My subarus:
