Old 08-27-2014, 04:50 AM
fasteract7's Avatar
fasteract7 fasteract7 is offline
Rear axle question
Was trying to loosen cover plate on inner end of rr axle as it goes into the diff, held with 5 12mm bolts. With bolts off and a goodly bit of prying, it didn't budge. Is this a matter of needing to "persuade" it a bit more vigorously or am I missing something?
THX
Old 08-27-2014, 03:57 PM
Re: Rear axle question
After you remove the 5 EIGHT MM bolts with the TWELVE MM heads, gently try to rotate the side plate using a square drift, if you have one and a small hammer.
Once you start to twist it/rotate it it should be able to be twisted off.
Old 08-27-2014, 04:16 PM
fasteract7's Avatar
As always, much appreciated...will follow those tips.
Old 08-27-2014, 05:11 PM
Sure.
BTW,
"Torque the side plates to 6.5-8.7 ft/lb."
