Old 06-20-2014, 08:58 AM
lightspeedrobot's Avatar
lightspeedrobot lightspeedrobot is offline
Time Travelling Robot
Re: Many Parts available (will continually update)
Mines a 92 with the standard tortoise shell pseudo woodgrain. I'm hoping this will do the trick, my blower refuses to turn on (even with a new blower motor). It's throwing a n air mix door code and I figure if I just replace both units the bastard should work. Fyi driving with that much glass with no defrost In the snow.... No bueno. Dangerous borderline crazy lol... Once your halfway over dinner summit in a blizzard there's no turning back though... I d ice on the inside of my window even lol
Thanks!
Teamwork makes the Dream work!
Old 06-20-2014, 08:04 PM
Sent you a pm 're control arms and polished headlights
Old 06-24-2014, 06:15 PM
andreoz andreoz is offline
Send a message via Skype™ to andreoz
Do you have the ABS control unit from under the front seat - part no
Nippon ABS Ltd 26720 PA010
Old 07-10-2014, 11:08 PM
Thanks!
I'll have to shoot you a PM. Sorry for not responding back.
I'll check on this. I have ABS modules but will need to make sure it's the same as yours.
Old 07-11-2014, 12:52 AM
scoobymal's Avatar
scoobymal scoobymal is offline
Still interested in the Stebro, waiting to hear from you Nate- guess you have been busy. Mal
Old 07-13-2014, 09:20 PM
Alex-svx's Avatar
Alex-svx Alex-svx is offline
Do you have brake and clutch kit to go hydraulic set up? I have the pedalset but missing the other stuff.
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
Old 07-14-2014, 06:41 PM
NJAL NJAL is offline
Hey , what kind of condition is the a/c compressor in? Also, do you have the compressor mount brackets, in believe there is two brackets, i need both. Do you have the a/c belt? If you have all of this , what kind of price can you give me on the whole package? Need all of this ASAP, i am going on a road trip in mid august and my fiance refuses to go untill i fix the A/C. Thanks
Old 07-30-2014, 08:19 PM
Chucksta Chucksta is offline
I need a driver's side power door lock actuator for a '94 ( it would seem to be that they're not all the same, as the one from my '96 donor car is different.).
thanks.
Old 08-01-2014, 04:17 PM
Jvan Jvan is offline
Any Bordeaux pearl rust free doors, can use both sides. I'd do a pick up, if you do have any.
Old 08-04-2014, 03:07 PM
Alex-svx's Avatar
Do you have??
Alexander (Norway)
My subarus:
Old 08-05-2014, 10:22 AM
I have to double check my maroon doors. I know I still have a Florida Bordeaux driver door still on a car. And I have a few passenger doors. Just have to compare to make sure if they're claret or Bordeaux.
Old 08-05-2014, 10:24 AM
Do you have??
What other parts specifically are you looking for? Most stuff you could probably find over there for reasonable prices especially considering the shipping cost.
In any case, so you have a hydro pedalset and you need the master with reservoir, all lines, slave cylinder? Anything else? What type of transmission are you using as the slave cylinder is different for a turbo style transmission.
Old 08-05-2014, 12:25 PM
Alex-svx's Avatar
I will use a turbo transmission. I have a cabel setup on my car now. But i only have got the hydro peal set from a member here. And the 5speed cross member i have. So i need all the other parts.
I really want a 6speed, only the crossmember that is different? If i change my mind.
Thanks for answer. If you have these parts what will these go for?
Alexander (Norway)
My subarus:
Old 08-05-2014, 09:35 PM
If you got the "young tom" style crossmember, that will work with a 6 spd as well. I will send you a PM
Old 08-26-2014, 07:54 PM
Psychosis5150's Avatar
Psychosis5150 Psychosis5150 is offline
Yugo aficionado
Have an auto front diff that's in decent shape? My axle stubs wobble like joysticks lol!
92 Teal 181K
4:11 trans
Lightweight crank pulley
Redline Shockproof
Trans Cooler
Viper 550 HF Alarm/Remote Start
18" Enkei Evo5's
