Old 06-08-2014, 11:29 AM
radarwhiz's Avatar
Fairmont State University
Fuel gauge fix w/pics
For quite a while now my fuel gauge has been working only intermittenly and gradually getting worse until it just stopped working altogether.
So I pulled out the sender unit and took it apart. The issue is that the wiper arm of the potentiometer loses its tension and failes to make contact anymore.
Here are both floats removed from the tank:
To remove the potemtiometer, unclip at the arrows:
Inside. Pry the wiper arm assembly off the shaft (make note of its position in relation to the float arm for reassembly):
Bend the wiper arm and other two contacts downward slightly enough to make contact again:
Press back onto the shaft and ensure that all three points are making good contact.
Do both sides and reinstall them in the tank.
This resolved my problems, I hope it works for anyone else who tries.
Elazar
'08 ML550 daily driver
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 06-08-2014, 11:42 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Re: Fuel gauge fix w/pics
Should put this & also my fix for the JDM Aircon into the "how to" section...
Old 06-08-2014, 07:51 PM
fasteract7's Avatar
fasteract7 fasteract7 is offline
Nice...appreciate your time posting this DIY
Old 06-08-2014, 07:58 PM
radarwhiz's Avatar
No problem at all. I just hope this is clear enough and helps others if they are having this issue. I'm also not sure that this will be a guaranteed fix but it's worked 2 for 2 so far and I'll try it on a third known bad one just to be sure.
Elazar
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
