Old 05-24-2014, 11:12 AM
FM977 FM977 is offline
Sometimes starter clicks but doesn't crank
Sometimes when I start her the starter will click when I turn the key, but it won't crank. If I turn the key off and on again enough times it will likely fire. It's almost as if the starter is beginning to seize up. Has anyone else had this issue? is it likely the starter going bad or could it be a wiring / grounding issue?
92 SVX LSL - 231k (SOLD!)
97 Legacy Outback - 227k
04 Porsche Cayenne S - 99k
95 Ford Ranger - 220k
Old 05-24-2014, 11:48 AM
gwynethh's Avatar
gwynethh gwynethh is offline
Re: Sometimes starter clicks but doesn't crank
You might be able to do the starter relay mod mentioned in this group and the other group
http://svxworldforums.com/view_post.php?post_id=35308
and
http://www.subaru-svx.net/forum/show...=starter+click
Old 05-24-2014, 12:11 PM
Wow! You go girl. God job.
