Old 05-05-2014, 11:38 PM
Tapani Tapani is offline
code 12?
Driving more than an hour this morning, stopped to open a gate, put the car in park and got code 12 - starter switch. The idle fluctuates from near stall to 2000 and back. Does this only in park and neutral.
The selector switch on the side of the tranny? I hope I can still start the car in the afternoon ��.
T
Old 05-07-2014, 12:52 AM
ShaneHobson ShaneHobson is offline
Re: code 12?
Your symptoms are the same as mine posted here :
http://www.subaru-svx.net/forum/showthread.php?t=62480
Problem still occurs in my car.
It currently has these error codes
23 = abnormal voltage from air flow sensor
12 = abnormal signal from ignition switch (http://www.subaru-svx.net/forum/showthread.php?t=62748)
37 = O2 sensor 2 inoperative
Old 05-07-2014, 08:20 PM
Re: code 12?
Thanks,
It's weird, and has happened only twice. Both times after driving a longer stretch. The problem is evident only in N and P. Letting it sit a while cures it. Hmmm..... The dash led indicators for lever position work ok.
Must be in the start inhibition circuit from the tranny.
Anyone?
I have a piece of wire with me to jump the starting relay directly from the battery if the tranny switch starts to act up . I have done the "bosch" mode. The previous incident was prior to doing this, though.
Tapani
