Old 12-21-2013, 11:22 AM
SUPER SUPER is offline
wiper hitting molding. Noisy
I have an intermittent issue with my drivers side (LHD) wiper. When traveling over 50 mph or so. and only sometimes, the wiper arm makes contact with the molding at the edge of the window. I am thinking the wind is pushing it just a bit more than usual to make this happen. Has anyone else dealt with this issue. Is it a matter of taking the arm off and moving it (adjusting it) one tooth of the spline over? Or is there some wear going on with the linkage or something?
Thanks in advance.
Old 12-21-2013, 12:59 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Re: wiper hitting molding. Noisy
What you said. Also try setting the wipers on winter mode.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 12-22-2013, 10:32 PM
Tapani Tapani is offline
I had the same issue - removed the "spoiler" fitted to the drivers side blade, set the wipers to winter mode as suggested and all is well.
I think the linkage may be worn and this makes the issue worse.
/T
Old 01-04-2014, 09:11 PM
moved the arm over one tooth on spline. we will see. Has not rained since I made adjustment. I did not notice any difference between winter and summer mode when I tried that first.
