Old 05-26-2013, 05:46 PM
shotgunslade's Avatar
Renovation Phase Finished
Well, I finished this phase of the SVX renovation today. Car has been back from Dave Heinrichs for 2 weeks, but needed to do a few final things. Replaced the rear seat backs, removed the windshield wiper arms, de-rusted them, and painted them metallic charcoal. Blacked out the vertical tire pressure tell-tale white shoe polish stripes on the tires. Looks pretty good.
And, of course, there is YT's fine engine.
Dont know where I'm going with this next, maybe some new front seats. I have been scoping out a roll bar, but it looks like it would really intrude on the rear seats, and I would really have to tear up the interior to attach the support legs to the rear strut tower.
Old 05-26-2013, 05:59 PM
Re: Renovation Phase Finished
That looks too good to race Dan.
It will look more impressive on the track, passing the rest.
Old 05-26-2013, 08:51 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Dan,
So, Tom never switched your car over to a Hydra stand alone?
Looking good!
Cheers,
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 05-27-2013, 06:23 AM
Yes. He did. He left the MAF on as one of the possible emissions compliance strategies. The idea was that for the emissions test I could reinstall the stock ECU, then after it was over put the Hydra back in. Only problem was that it wouldn't run at all with the stock ECU. never got around to removing the MAF.
Old 05-27-2013, 07:40 AM
Did they paint over the rubber strip under the side garnish pieces? It's hard to tell from the pictures. All in in all it looks great. I remember seeing it at Reading and noticing that the clear coat had failed and the paint was pretty bad.
Old 05-27-2013, 09:46 AM
I'm not sure what you mean by the side garnish pieces. It's clear the side plastic panels were removed before painting. If you mean the rubber strip that is under the trim piece that sits under the rear quarter window and above the rear wheel, immediately above the rear fender on each side, no, he didn't paint over that.
My final dose of bling: Charcoal metalflake windshield wiper arms.
Old 05-27-2013, 10:20 AM
Yes that is what I meant. Nice to hear that it was all done right.
Old 05-27-2013, 11:03 AM
theflystyle's Avatar
Little off topic - You have a very nice home, well at least the important part (garage)
1994 SVX LSi
2008 Legacy 3.0R
Old 05-27-2013, 11:21 AM
Thanks. Got to have room for those toys.
Old 06-05-2013, 07:28 PM
Dan, she really looks great!! Once I can finally get us to agree on our new house I hope to build a garage similar to your own, with a lift or two of course. The I can get started on a mid engine race car I have been cooking up for the past couple years... Maybe a couple track days... who knows Again, the car looks great and I hope you get much more enjoyment out of her in the future!
Old 06-06-2013, 05:55 AM
At one point, you may remember, I planned to get a portable low lift for the garage. Never seemed to make it to the top of the priorities. Now, don't really see the need. don't think I will be attacking any major build projects in the near future.
You should come visit and take a ride. Your last tuning session really made the car right.
Old 06-06-2013, 11:16 AM
Huskymaniac's Avatar
Uses the ignore feature
I have to say, you have done a great job with that car. Obviously more HP can be had with a turbo or supercharger but you have brought the car at least up to modern standards for NA V6 sports cars. All of your mods make perfect sense and you didn't appear to push anything too far and risk making the engine unreliable. I would expect the car to be very drivable around town and reliable while still being very quick. I bet you could give a 370Z a run for its money. If you ever think of selling...PM me.
Tony
Old 06-06-2013, 11:31 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I think a photo shoot is in order
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 06-06-2013, 01:25 PM
It is very driveable around town now that Tom has finished the tuning. Like any high lift, long duration, non-variable valve timing engine, it will sometimes stall, especially when cold, but nothing like the old 5MT stall syndrome. The only problem is that it didn't pass emissions in NJ so, I have a Collector Car registration. All in all, I'm very satisfied, although, it has been a pretty expensive process. This makes it worth it.
Old 06-06-2013, 04:20 PM
SVXRide's Avatar
Dan,
Where was the DynoJet you ran on for these plots? Do you have a "corrected" plot? Looks like a credible 300 HP at the crank
Was this before or after YT's latest tuning session?
Cheers,
Bill
