Old 05-12-2013, 10:14 PM
RogerGault RogerGault is offline
1994 LS Parts
OK, I finally got a list together.
If you’re interested in this stuff, PM me.
I can send pics.
I’d just as soon keep this stuff in the community (and I'm lazy), so I’ll take any offers I get that even close to what I think I can get on e-bay.
I’m not trying to get rich here – remember, I tried to give the car away if somebody would come haul it off. Frankly, I just couldn't make myself send scarce parts to the crusher, so I pulled them before the bad guys came for the body. I guess that makes me a certifiable car geek.
The car was a 1994 LS, painted “Emerald Pearl” and the specs I’ve seen say that means it had a “beige velour” interior. Probably right, the velour parts look kinda grey to me. The vinyl parts are a little more what I would call beige. The plastic bits had sun-faded a sort of tan. I don’t have any SVX’s around here to compare it to.
Stuff will be shipped from Austin, TX. If you come get it, and I don’t have to box it up, it gets amazingly cheaper.
Stuff I saved from the car that I don’t need - in no rational order:
ABS Controller
Air Conditioning Control
Door Lock Timer
Shift Lock Unit
Stop Lamp Checker
Transmission Control Unit
Ambient Air Temp Sensor
Sunload Sensor
Air Bag Controller
Air Bag, Driver
Air Bag, Pass
Air Bag Harness (yellow cables, both sensors)
Radiator
ABS Hydraulic Unit
A/C Condensor
A/C Evaporator Assembly
Heater Core Assembly (man, that's a nightmare to get out)
Blower Assembly (for HVAC)
Steering Wheel Cruise Switch (Resume/Coast, etc.)
Driver’s side Window Switch (dead)
Pass. side Window Switch
Rear Window Switch RH
Rear Window Switch LH
Rear Room Light
Dash Air Vent (cracked)
O2 Sensor (1)
Radio (dead)
Outside Door Handle (Both sides)
Inside Door Handle (Both sides)
Door Latch (Both sides)
Side Mirror (Both sides)
Window Mechanism, Door, (Both sides)
Rear Side Window Mechanism LH – for parts bad motor/cable
Rear Side Window Mechanism RH
Side Glass – all 8 pieces - some of the weatherstrip glued to the glass is trashed
Brake Master Cylinder and Booster
Inside Mirror - silver is not perfect on the edges
Starter Motor
Center Grille
Driver’s Headlight
Front Turn Signal Lights (both sides)
Tail Lights (all 5 pieces)
Rear Quarter Panel Garnishes (“SVX”): both (some tabs broken)
Interior – Rear Side Panel and Arm Rest LH (both sides)
Console Compartment Release Button – (Repaired- I think it will work)
Glove Box Interior
Glove Box Door (marginal)
Sunroof Assembly Complete – for parts – (Frame badly rusted) - (small plastic bar with hole in both(?) ends that I can't identify is broken and was lying in the track blocking it, but the mechanism seems to work fine with it out. ???)
Trunk Interior including Carpet – Almost like new. Carpet had some rust stains, but they mostly disappeared when I washed it. Nicest part in the car.
Front Wiper Arms
Rear Wiper Assembly - Complete
Power Antenna Assembly
Cowl Panel Net (plastic grille under wiper arms)
****er w/ Cable
Shifter Console Cover
Instrument Cluster (“Combo Meter”)
Instrument Cluster Surround
Radio Door (only, no mechanism)
Ash Tray and Cover
Cigar Lighter and “Wood” Panel
Gas Pedal Assy
Brake Pedal Assy
Front Strut Covers (snap on top of towers)
Upper Radiator Brackets
Steering Wheel (w/o airbag&switch) (covering is poor - starting to flake)
Pass Grab Bar (strap only, no mounting)
Box of Misc Weatherstrips
Things I plan to keep in the unlikely event that I need them.
If you really need them, I can be bought.
Washer Bottle, Front
Washer Bottle, Rear
Fuel Filter
Evaporation Canister
Dash Push Buttons, RH
Dash Push Buttons, LH (one of these has a button cap that falls off. Don't remember which at the moment. Glue)
Wiper Select Switch
Side Mirror Control Switch
Driver Side Sun Visor and Vanity Mirror (Visor stays up. Mirror has been removed, and the wire pulled out. of the visor.)
Passenger Vanity Mirror (Visor was toast)
Door Lock Switch (from console)
Throttle Cable
Horns (2)
Courtesy Lights from Doors (RH, LH)
Hood Release Handle
3rd Brake Light
PS: Since I'm using the harnesses in my project car, I had to reverse engineer the wiring differences between my 1992 factory manual and the actual 1994 wiring. There's quite a bit of change due to moving the Cruise Control and Security System to the back of the car (and nuking the Automatic Shoulder Belts). I couldn't find a 1994 wiring diagram. It may be somewhere, but I couldn't find it. I basically re-drew the factory wiring diagrams to match the 1994. I did not make the changes for the new passenger Air Bag. Is anybody interested in that data? I can PDF it and put it up here if so.
Old 05-19-2013, 01:58 AM
cozykat's Avatar
cozykat cozykat is offline
Still rebuilding my block...
Alcyone Silver Contributor
Re: 1994 LS Parts
Yay you are in TX!! Sent you a PM.
Marisa
Old 06-04-2013, 01:38 PM
SVX_MY_BABY's Avatar
SVX_MY_BABY SVX_MY_BABY is online now
Re: 1994 LS Parts
looking for a/c condenser & evap.
Peter
Old 06-18-2013, 06:16 PM
fasteract7's Avatar
fasteract7 fasteract7 is offline
Re: 1994 LS Parts
ABS valve relay..the one with the 5 prongs under the "ABS" black plastic cover on the pump..?..got one
THX
Old 07-15-2013, 03:17 PM
scoobydrvr scoobydrvr is offline
Re: 1994 LS Parts
Looking for fuel sending unit, the one on the drivers side. Any chance yours is in working order?
1996 SVX LSi : Work in progress, future garage queen
2013 Acura TSX: Mistake
Old 07-23-2013, 06:39 PM
joneshf joneshf is offline
Re: 1994 LS Parts
Do you still have the radiator?
