Old 05-09-2013, 09:35 AM
reberto reberto is offline
Anyone need a power antenna?
There are two SVX's at my local pick n pulls both with good, intact power antennas. Anyone in need of them? I can go grab them if there is a need for them!
Old 05-09-2013, 10:05 AM
Huskymaniac's Avatar
Uses the ignore feature
Re: Anyone need a power antenna?
Any idea what the cost would be?
Tony
Old 05-09-2013, 10:08 AM
scoobydrvr scoobydrvr is offline
+1, would be interested depending on price.
Old 05-09-2013, 10:35 AM
Pick N Pull charges $24 for the entire assembly, and the whole assembly should have no problem fitting into a medium USPS Priority flat rate box, which is $13 for 2-3 day shipping
Old 05-10-2013, 08:42 AM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
Do you know if they come with the shaft? If so, i'd be interested as I just bent mine again DOH!
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
Old 05-10-2013, 08:45 AM
From the first post, it seems they do but some clarification would be nice. If the answer is yes I'll take one!
I'm interested. It seems like it is the least expensive option.
Tony
